Question about Home
I have 25 yr old eljer lavatory faucets that leak. Local hardware says they'll replace washers if I bring them the stems. How do I do it. The handles appear to cover the shafts. There's a little slot in the covering below the handle top. Is this a catch I must open? Thanks. G. Evans
  • gevans8 Nov 04, 2010
    I know the problem is caused by the need for new washers at the base of the faucet stem. I don't know how to get the shroud type faucet handle off the get to the stem nut. A plumber once referred to this type bathroom faucet as a 'Brenda Eljer lav' if that helps. Thanks
    Thanks, ewiz Your diagram shows a removeable cap. . My handles are one piece with no separable cap.
    Top Expert:
  • 80,417 Answers
Step 1. Turn off the Water: If there's a shutoff valve beneath the fixture, turn off the water at that point. Otherwise, turn it off at the main house shutoff valve in the basement, utility room, or crawlspace. Turn off the hot water supply at the water heater Step 2. Take the Faucet Apart: Start by removing the handle (this may not be necessary on some older faucets). Loosen the Phillips-head screw, which usually is beneath a decorative cap in the center of the handle. The cap either unscrews or snaps off when you pry it with a knife blade. Next, lift or pry the handle off its broached stem. Unscrew the packing nut beneath the handle, exposing the rest of the stem. Remove the stem by rotating it in the "on" direction. It will thread out. Reinstall the handle if you have difficulty turning it (Fig. 1). Clean chips from the faucet cavity, but do not use harsh abrasives or a file. please see the diagram of a typical washer type bathroom faucet. I have 25 yr old - emissionwiz_2.jpg
Posted on Nov 04, 2010
  • yadayada
    yadayada Nov 04, 2010
    there must be a screw in the handle then? without the exact model number of the faucet I am kinda handicapped here.
  • yadayada
    that little slot is a screw, my worry is that the screw after all these years will be rusted in place and you will either break it or strip it out trying to remove it. You are going to need tools, a flat bade screwdriver and a good assortment of box end wrenches, do you have a tool set?
    Brigadier General:
  • 3,917 Answers
Most of the times when a faucet leaks it is due to a washer. Over time washers warp or break especially in the hot water side (if you have two separate faucets). What you want to do is use a screwdriver and removes the faucet until you get to the washer which is a rubber piece with a hole in the middle then take that to your local hardware store and find a matching replacement. It is fairly simple to do and the main cause of leaky faucets.
Please check the bellow links to have an in-depth knowledge related to your issue:-
http://www.ehow.com/way_5714935_eljer-bathtub-faucet-installation-instructions.html
http://www.ehow.com/how_6705402_fix-leak-tub-faucet.html?ref=Track2&utm_source=ask
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Double faucets cartridge replaced still drips
My best advice
is to believe everything you just experienced...
(Perhaps an UNSEEN flaw in the "MONOBLOCK")
Buy the replacement faucet... shop around:
I spotted it on eBay... (number not close...)
((but still reasonably priced)).
AMAZON
American Standard 1480 101 002 Seva Single Control Lavatory Faucet with...
Also went to eFaucets (but their site was stunned
(normally GOOD resource... ))
http://efaucets.com/
eBay (concierge... buyer protected... FREE ship'n)
American Standard 1480 150 002 Seva Monoblock Single Lever Handle Lavatory...
Save the old one (parts)and DIAGNOSE
it in your SPARE TIME...
Hope this helps
Carnac the Magnificent
Oct 19, 2017 | American Standard - Lavatory Faucet -...
Eljer lavatory sink faucet leak
Check washers. They probably are worn out.
Jan 13, 2013 | Home
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
Constant slow leak
more than likely hot side that is leaking as hot water tends to soften washer...try shutting off hot water angle stop under faucet...if drip stops it the hot water.. try pulling handle off and tightning nut that hold stem in place..
Nov 21, 2010 | Hansgrohe - Lavatory Faucet - Centerset -...
Water leaking at handle when turned on
1- Hanldle may have a cap that will come off to access screw to loosen or allen screw on the handle to remove it.
First thing you can check remove handle and make sure the nut that holds stem down is not loose. You can tighten it and try this first just replace handle turn on and check for leaks.
If not please go to step 2 in removal of stem
2- Cut water off and remove handle to gain access to stem. Next remove stem by untighting nut at the base. Remove stem and replace o rings on stem about middle of it. That will stop water from leaking at the base.
May 19, 2010 | Kohler Fort© Widespread Lavatory Faucet...
How to remove retaining nut on two handle faucet so I can remove stem? Thank you. John
sounds like you need a basin wrench that is made for taking off nuts like this one.  you can find one at local hardware store.
Jun 20, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Replace inside stem on hot water Eljer shower faucet
Sounds like you might need a gear puller -- hardware stores would have them -- or auto parts.
Spray with contact cleaner wd-40 first, then install puller, depress ring and crank away at the puller.
Apr 21, 2009 | Home
Eljer lavatory faucet will not shut off. Chrome knob is stuck.
If you are trying to remove the handle you need a handle removal tool sold at all hardware stores
Nov 10, 2008 | Plumbing
Delta Faucet Kitchen Single Pull
Yes, It can be fixed but it isn't a washer. There is a replacement stem for the faucet . They are readily available at most big box stores and possibly the local hardware store. Bring your faucet model number with you.
Phil
Oct 17, 2008 | Delta 2402 Classic Single Handle Kitchen...
Home Logo
1,588 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
