Question about Epson Stylus CX7400 AllinOne InkJet Printer
I just set up an Epson Stylus cx7400. I have all new ink in it. However it keeps printing blank pages. I have done the trouble shooting and all the recommendations and it is still printing blanks. I do not know what elese to do. I am a full time student and own a company and feeling very frustrated right now.
SOURCE:
  • 357 Answers
SOURCE: Epson Stylus CX7400 Black ink won't print
Make sure the tape has been removed from each of the cartridges.
Clean the head and the nozzels.
The cartridges may be defective, afterall they come from China.
Try a new cartridge and see.
Good Luck.
Posted on Feb 16, 2009
SOURCE: Epson Stylus CX7400 Ink Light Problem
You need to open up the maintenance window and go thru the motions that you are changing the cartridges and this resets the ink levels back to full and sends data to the printer saying that they are full and the ink light disappears and it prints fine !!!
Just changing them doesn't seem to do the trick like on a lot of printers
Posted on May 15, 2009
prawinmv22
  • 106 Answers
SOURCE: Epson Stylus CX7400 won't print
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Posted on Jun 11, 2009
Remag1234
  • 387 Answers
SOURCE: Epson Stylus CX7400 won't feed/load any type/size of paper
You may have gear, roller problems. Try the head alignment process, if need be call Epson tech support. Epsons are really cheap if you need a printer. If you are going to buy a printer then Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Posted on Jun 23, 2009
cns assoc
  • 677 Answers
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
I need to restore the software for my Epson Stylus CX7000f PRINTER in my new computer. I can not find the original disk, from where can download the software
The Epson Stylus CX7400 Color All-in-One printer prints up to 28 pages per minute of black ... Stylus CX7400 ink jet all-in-one, 69 black ink cartridge (T069120), ... Best of all, you don't need to wait for an available computer to get started. .... Also, given my experience, one paper jam can cause your printer to ...
www.amazon.com/Epson-Stylus-CX7400-Printer.../B000SDXZX8
Jul 16, 2010 | Epson Stylus CX7400 AllinOne InkJet...
Jan 29, 2010 | Epson Stylus CX6000 All-In-One InkJet...
I have an Epson CX4800 that just stopped printing. I followed the Troubleshooting steps on the Epson site (including new ink cartridges) but nothing has helped. the print job does reach the printer - but...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 28, 2010 | Epson Stylus CX4800 All-In-One InkJet...
How to change ink cartridges on Epson Stylus CX6600
i just buy new cartridge ink for my epson stylus 4100 and when i print out didnt print its only a blank page what should i do
Dec 04, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printing blank pages
To mutch time the printer stopped. first check ink level, and use clean internal program
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Epson Stylus C45 not printing
common issue, the printer will still shoot blanks even if you try another ink or do several head cleanings.
i got a lot of them with that problem, but since epson prints beautiful photos, i don't mind exchanges or getting a new one.
Feb 07, 2009 | Epson Stylus C46 InkJet Printer
Ran out of black ink
The manuals,online guide and trouble shooting sections could help you resolve your problem. Contact support has a chat facility on some pages that may help.
Click this Link
Under Select a Product Range
Choose Stylus C45 on the webpage
Under Select an OS
Choose the operating system1.gif on the machine where you will install the printer on the webpage
Click Confirm Selection
The manuals and documentation link will allow you to download manuals that were on your CD ROM
you may want to bookmark the online guide, if present, to help with future problems -- that probably was not on the CD
Click the back button on the browser
click the Drivers and Software Link
This allows you to download software files that were probably on your installation CD
Click the back button on the browser again
Trouble Shooting and Contact Support could be an interesting link in the future too when and if you have problems.
I hope this helps
Dec 13, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus CX7400 AllinOne InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
