Question about Toshiba Satellite P35-S609: Pentium 4-3.2 GHZ, 512MB RAM, 80GB Hard Drive, DVD-RW/CD-RW, 56K Modem, Network ... (SATELLITEP35S609PENTIUM) PC Notebook
Laptop restarting my laptop after starting goes to the window xp intro screen then restarts again and again. it wont even recognize the boot disc that came with it. i had the mother board and monitor replaced a few months ago at best buy. i think the hard drive is bad.
  • fixitnow22 Jun 15, 2008
    ok i did the F8 like u said and it comes "unmountable_boot_volume" and it talks about removing newly installed hardware and or software which i havent added anything but mp3 files. then it keeps restarting.
    President:
  • Toshiba Master
  • 1,314 Answers
Although it could be the hard drive, it could be any number of things as well. First, when the computer starts up, press the F8 key to bring up some options. Select disable automatic restart. This should allow the computer to stop at a blue screen so we can get some information from it. Do this and report back what that information says and we'll go from there. Thanks.
Posted on Jun 14, 2008
  • Kevin Shafer
    Kevin Shafer Jun 15, 2008
    Okay...the unmountable boot volume error comes up when your hard drive goes bad. Sounds like you need a new hard drive.
I am stuck in Safe mode with command prompt on my Dell 620 laptop windows xp every time I type a command it says it is not recognized as an internal or external command, operable program, or batch file....
try restarting the laptop and before anything pops up on the screen hit the f8 key and the boot menu comes up then start in last configuration that worked and see if it helps
Sep 30, 2013 | Dell LATITUDE Computers & Internet
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
My drivers got renamed some how and then they crashed i have it so it will boot up now but windows xp is gone try to reinstall wit windows xp install disc and its stuck on a screen saying can not complete...
Thanks for using FixYa.
The Windows XP setup is detecting that you have a current installation of Windows XP. What you need is to do a clean install. You can find information on how to clean install Windows XP here:
http://michaelstevenstech.com/cleanxpinstall.html
Make sure that you back up all your data before doing a clean install as this will delete all data on your machine.
I hope this helps. Thanks and good day.
- HotRatchet
Feb 14, 2010 | Office Equipment & Supplies
I have a dv100 laptop when you turn it on it goes to the windows xp loading stays there then shuts of and restarts the same way I cant get it to turn on. I can occasionaly get the safe mode screen it still...
Try to Repair XP
  1. Insert Windows XP disc to CDROM
  2. Select Boot from CD--option
  3. Select "R" for Repair---it will enter to Recovery Console
  4. run Command---chkdsk /r
  5. after completion--reboot system and check
Oct 01, 2009 | HP Pavilion dv1000 Notebook
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
My laptop after starting goes to the window xp intro screen then restarts again and again. it wont even recognize the boot disc that came with it
All right, first you gotta check your BIOS settings goto to bbot tab and check the order of your drives at the top must be the CD-rom drive, then check that "boot to optical devices" and "boot to removable devices" are enabled then restart your computer with  a bootable cd and goto repair mode, and perform check disk to the drive in your windows is installed. The command is "chkdisk C: /F /R" hope that helps, please rate the answer
Jan 21, 2009 | Toshiba Satellite P35-S609: Pentium 4-3.2...
HP Pavilion ze5500 - Laptop won't recognize hard drive.
Hi. Once I had this similar problem with a HP Pavilion dv9000. "No Operating System"; "Windows Recovery Console cannot continue because there's no HD present..press F3 to Exit". No progress with Safe Mode nor Command Prompt, etc.
Then I went to the Bios, change tab to "System Configuration" and change the "Sata Native Support" to disable, whitch says that by changing to disable the HD would work better if the Operating System are Win2000 and Win9x.
Hit "Safe and Exit" and the computer started normaly!
I relly don't know how or why. It just work.
I don't know if would work for Linux (mine had Windows XP) and don't know the Bios view of your laptop. But you can explore and give it a try.
Hope this helps.
God Bless You!
Jan 06, 2009 | Computers & Internet
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Restarts before windows loads up.
hey hey chill...simple my friend just have your windows service pack with you inhand.Turn your Laptop on immidiately when your CD-ROM/DVD-ROM starts flashing its light, open it then insert your service pack disc (its the CD/DVD you receive when purchacing the laptop) then let it restart again...then again when it starts press F8 repeatedly until you enter a some menu then re-install the Windows Xp again from the disc and walla your Pc will be fresh again...
Feb 24, 2008 | Fujitsu Siemens Lifebook T4010 Tablet PC
Computers & Internet Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
