SOURCE: drive belt out of alignment
check pulley is fully bolted home. also fault could be due to the bearing spider (on the drum) being broken or cracked on one leg. if this was so, would expect spin with clothes to be very noisy. get gack to me if you want. the belt is a stretchy belt ie no adjustment for tightness
SOURCE: How to replace belt??
there are two wheels unplug every thing and turn upside down you will find the other wheel
SOURCE: replaced belt but it keeps slipping
There is a pivot spring on the side of the motor. It is a large "U" shaped spring. This is the only spring there is on this unit. The motor itself sits on a floating plate. Make sure this plate moves side-to-side. If it doesn't it will need to be broken loose.
SOURCE: HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
