Question about Sharp 13VT-R100 13 in. TV/VCR Combo
The volume level is as high as it will go, but not loud enough - can i get it to go louder?
  • pampadding Nov 04, 2010
    i have a Sharp tv vcr combo that is at least
    15 years oldd - 13VT-L100. the volume is at
    its highest, but is hard to hear - any way that
    can be adjusted to get louder?
    thanks
  • Sharp Master
  • 736 Answers
I am not certain without the manual before me whether or not this model has an audio adjustment choice in its menu. If it does please increase the treble and the bass as high as it will go. If there is a surround button or adjustment in the menu choice please listen to the sound with both the surround on and off. Please try adjusting the volume on the devices you have connected to this television. Is it still loud enough when playing a VHS tape? If so then that indicates that the sound problem is with the connected device.
You may need to purchase a sound bar. If you have a cable box or a converter box the yellow cable would connect to this television still but the red and white audio part of the cable would connect to the sound bar. Unfortunately you would not be able to do anything about low level when playing a VHS tape because this television doesn't have an audio ouput I don't believe.
Posted on Nov 04, 2010
  • Sharp Master
  • 5,138 Answers
The only way to get more sound is if you have external outputs that you can connect to stereo
receiver and Run sound thru the stereo.
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Oct 26, 2013 | Nokia 6303 Cell Phone
How can I increase the loudness of the CDs burned on the internal CD-RW drive?
You can use a free software audio editing and recording program called Audacity. Using this program load your stereo track(s) into Audacity, then look in the effects menu and select normalize. Make sure to set highest loudness level to 0 db, which is the maximum digital volume level. You can hear the difference in volume when you use the test button. If you can't still get enough over all volume level with the normalize feature then you will need to compress and limit the stereo track, but I don't suggest getting your over all loudness levels that high because it ruins and lowers the dynamics of your music. Another words when you compress and boost the over all loudness of your album then all your music is at the same highest audio level which is very ear fatiguing. It may sound better to you at first at louder volume levels but you will quickly learn to hate it over time because it does not sound natural. That is why most music today is all about loudness and ear fatigue. And because of the loudness wars going on today every Record company is trying to have the loudest album out there thinking it will sell more copies. It is all false baloney, it really should be about the quality and dynamics of your sound instead of how loud it is.
May 23, 2013 | Fostex MR16HD/CD Digital Recorder
Fender ultra deluxe amp volume max out a number 7 volume control. will not get any louder
It is likely that the amp is flat topped at the 7 setting. When the amp is producing the maximum voltage output it is capable of, that is ALL you can get out of it... The numbers on the dial mean NOTHING and are only relative. If you have high output guitars you might find the maximum might only be 3 on the dial for example...
If you need it louder, get a bigger amp and speakers. You should ALSO get a sound meter and follow OSHA guidelines for sound exposure... I know several musicians that now are nearly deaf because of being exposed to high sound levels... their music careers are now gone as they can no longer hear well enough. You need to protect your hearing for the long term. Great musicians don't need loud, but quality and inovation in their music.
Jan 07, 2011 | Music
32LG30 television, volume too high from level 0 to 1
If you are using a cable box...turn down the sound on the cable box.
Jun 24, 2009 | LG 32LG30 32 in. LCD HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Volume not loud enough
Actually there is a way. If you re-encode the file using an mp3 conversion utility, you can adjust the volume there
Jan 19, 2008 | Philips GoGear SA178 MP3 Player
TV Volume settings
These are all settings that are put in by the factory and cannot be changed.
Nov 28, 2007 | Televison & Video
Hey everybody...
I guess hope you found the solution man...but you if not or for the people with the same peoblem that trying to find the way to make their amazing Sandisk Sansa clip...I have a weird but works solution...
So this what you need to do to make your player louder:
1)press to home butten
2)go to settings
3)go to system settings
and now comes to weird/funny part...if you'r an American or the "Volume" section apear to you than select it and choose high insted of normal otherwise when you got your player you pobably choose everythng other than North America as where you live...
so what you need to do is to Reset Factory Settings then press Yes then press English and lastly press North America...I guess if your from Iran you ****** off right...but ****....if it will make your Sansa go louder than **** it...
well hope I was helpfull for someone and I hope you will enjoy your player better than before...
peace...
Nov 10, 2007 | SanDisk Sansa e260 MP3 Player
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
184 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
