Question about Simac Ice Cream Makers
Blade stops turning but motor still running
Old machine from my father. Tried making ice cream but after a short while the blade stopped spinning, stalled. The motor and belt are still turning but the frozen layer of ice cream on the inside of the bowl is too much for the blade to cut thru. Is this normal? Is the connection of the blade shaft to the drive pulley designed to "slip" under heavy load? The instructions say to "churn" the mix for about 20 minutes but we only ran about half that before the blade stalled. While there was a thick buildup of frozen [firm] material on the sides of the bowl the material in the middle was still fairly runny.
Would appreciate your comments.
  • dquesnel Jul 21, 2008
    Blade won't start turning
    Novelist:
  • 97 Answers
Hi Lew 2!
Sounds like the belt might be slipping prematurely. I'd try cleaning the belt and all the pulleys with an alcohol based solvent or rubbing alcohol (clear) to remove any excess oils that might cause slippage and see if that helps Is there any type of belt tension adjustment? If so, also try tightening the belt.. If the problem persists, you probably need to replace the belt.
If this helps, after the churning stops, remove the paddles and cover the top with plastic wrap or wax paper and allow the mixture to "firm up" in the ice bucket nother 10-15 mnutes, and then enjoy a great old-fashioned treat!
Hope this is a help, let us know how it goes, and good luck!
-WB
Posted on Jun 14, 2008
I have an ice cream maker ice 45u but the mixer blade is not turning. The power is there because i can hear it and when i pull the leaver down the cogs turn on the sprinkler system are turning i have...
Check that all gears are in good working order. The paddlewill not turn properly and the motor will not run if the gears are worn ordamaged gears. Inspect the paddle for damage and replace if necessary. You alsomay need to replace worn or damaged gears in the motor. Lubricate the motor,drive shaft and motor bearings. Hope this will help you. Good Luck.
Sep 03, 2011 | Cuisinart ICE-45 1.5 Quart Ice Cream Maker
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
The motor works but won't turn the blade. As soon as I turn it on, it sounds like it gets stuck and stops. What is going on?
The inner gears are probably stripping. This seems to be common on the rival 8550-X-5. I will never own another rival because mine was that way almost from the start.
Jun 29, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
Why does my blade not turn on my Rival 8550-X 5-Quart Wooden Electric Ice Cream Maker?
The dasher (blade) is supposed to remain statioary while the motor spins your bucket.
Jun 27, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
Machine is model 750-27can you help me? runs for only about 5seconds not long enough to make ice cream
Welcome to FixYa
An electric ice-cream maker is a tabletop appliance for mixing and freezing ice cream at home. A small electric motor drives gears that turn the canister filled with the ingredients for ice cream. The canister is surrounded with ice and rock salt to freeze the contents. Alternately, a hand crank on top replaces the motor.
Although durable, ice-cream makers can require a few repairs. A common problem is damage to motors or gears from mixing too large batches of ice cream or from neglecting a jammed mixing paddle. The electrical cord can fail and motor bearings can dry out.
Read Following ...
  • Use your cylinder bowl correctly. If the cylinder isn't handled properly, your ice cream won't set. Make sure it is dried completely after washing so ice doesn't form on the walls, make sure to leave it in the freezer overnight before making ice cream and don't leave the bowl out at room temperature before using.
  • Check your freezer door. If it isn't sealed properly, or if it's constantly being opened during the freezing process, your ice cream can't set properly.
  • Handle the ingredients correctly. Don't let the ingredients warm and don't overfill the bowl. Check the manufacturers recommendations for the maximum bowl capacity.
  • Clean and dry your machine thoroughly. Use a damp cloth on the motor assembly; never immerse. Make sure to wash the lid, blade and cylinder according to directions and make sure the cylinder is absolutely dry before freezing.
  • Contact the manufacturer's support site only after you have exhausted your options. They may walk you back through the steps you've already taken, but at best your problem will get fixed far more quickly because you eliminated the easy problems in advance.
I hope this Instruction guide will help you Click here Read carefully Instructions[Specifically Page27, 29,31]
OR click here
Just Check this Link too
Thanks for Contacting FixYa...
Jun 27, 2010 | Taylor 632-27 Ice Cream Maker
I need beater with its blade and a pipe for taylor machine
you can call Rick at Restaurant Parts and More, 1-888-814-1110. Have you model and serial numbers. He can most likely help you.
Apr 14, 2010 | Taylor 632-33 Ice Cream Maker
OUr rival 8550-x 5 quart wooden electric ice cream maker doesn't turn the blade in the canister. The motor is running but the blade doesn't turn in the canister.
take it apart and find the striped gear the motor actualy turns at 2000 rpm and has a reduction unint inside
eithor the gear is striped or the grub screw fell out of the drive gear could also be a drift or sheer pin on the main shaft
Aug 03, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Ice Cream not freezing
Yes, they stop working sometimes. Same thing happened to me.
The Cuisinart ICE-20 bowl is precisely the same, and works with the Krups 337. You can buy the Cuisinart bowl separately. It costs nearly as much as the whole machine, but what can you do.
Jun 26, 2008 | Krups 358-70 La Glaciere 1.5 Quart Ice...
MOTOR DRIVE DOES NOT TURN
Dear Dannyvk,
I am having exactly the same problem with my rival 8200 ice cream maker. It worked once and stopped usual, when I first used it. The ice cream was wonderful.
However, when I started to make a second batch, the ice cream maker just hummed after I plugged it in. No movement of the pin/hub whatsoever. I tried to move it, by placing the steel can on top and moving it side by side. I plugged it in again, and experienced the same old humming sound.
Is it a fuse? Is the motor blown? Is this something that a small appliance dealer can repair at a reasonable cost? Can anyone help? I am so disappointed!
Faithful in Christ,
D.
Mar 12, 2008 | Rival 8210 2 Quart Ice Cream Maker
Ice Cream Makers Logo
319 people viewed this question
Top Simac Ice Cream Makers Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Are you a Simac Ice Cream Maker Expert? Answer questions, earn points and help others
