Question about Panasonic Panafax UF-9000 All-In-One Laser Printer
Scanner error Looking for a service manual for the Panasonic Panafax UF-9000 or instructions on replacing the scanner unit
  • 134 Answers
Try Ebay. You can get a lot of service manuals there.
Posted on Jun 14, 2008
Free scanner driver for UF 9000
http://www.panasonic.net/pcc/support/bfax/uf-9000/index.html
Jun 23, 2012 | Panasonic Panafax UF-9000 All-In-One Laser...
I need the drivers for the Panafax UF-9000
You can download the drivers and software for
Panasonic UF-9000 Business Fax (including Panafax Desktop) from here:
Nov 23, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Error Message Reads: Check Scanner Unit E01-31
try checking the scanner cable . look through the glass back right . you will see a usb cable.. check both ends.. if there connected properly and you still get the error.. you need to replace the whole scanner unit
Oct 14, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
I'm getting the error code e01-31. what would I need to do? Thanks
Oct 06, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Error Code 720 on Panafax UF-9000
error 720 means unable to connect to the POP server.. incorrect POP server ID or POP server is down
Apr 24, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Scanner replacement
I don't know how far you want to strip this, but if you're getting a scanner failure error, clean the underside of the scanner glass and the scanner mirrors then check all the connections (i've found this can cure the fault).
(1) Remove the ADF Rear Cover
(2) Remove 1 Screw from ADF cover
(3) Disconnect the Harness on the ADF PC Board
(4) Open the ADF.
(5) Release the Latch of the Left Hinge with a small
Straight Edge Screwdriver and remove the ADF.
(6) Remove the Control Panel Unit.
(7) Remove 8 Screws from scanner base
(8) Remove the Wire Clamp
(9) Remove the Scanner Cover Assembly
(10) Disconnect the Harness
(11) Remove 2 Screws
(12) Remove the Scanning Lamp
13) Slide the CCD Unit.
(14) Remove the CCD Harness Seal
(15) Remove 2 Screws
(16) Remove the Seal Plate
(17) Disconnect the Flat Harness
Note:
There is no need to disconnect the front FG
Harness that is attached to the CCD Unit.
(18) Remove 3 Screws and 2 Screws
(19) Remove the Main Board Cover
(20) Disconnect all the Harnesses.
(21) Remove 4 Screws
(22) Remove SPC PC Board
Jun 14, 2008 | Panasonic Panafax UF-9000 All-In-One Laser...
Panasonic Panafax UF-9000 All-In-One Laser Printer Logo
162 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
