Question about Lexmark X1240 All-In-One InkJet Printer
No communication printer will not communicate with computer.....have installed and uninstalled several times. checked cables.....getting frustrated
  • Anonymous Jun 22, 2008
    problem communicating with printer
  • mikewlker Jun 30, 2008
    Computer and printer communicate but nothing prints out on paper. Feeds through and all but does not print text.
DID NOT WORK!
Posted on Jun 21, 2008
    Genius:
  • 1,027 Answers
From the Lexmark web site:
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=:::-1::
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct driver for your model and OS.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected. Search the KnowledgeBase
Posted on Jun 14, 2008
Printer S405 will not communicate with computer, USB has been checked and the printer has been uninstalled and re-installed about 5 times now - help!
How is the printer connected to your computer? Wireless or hardwired with a USB cable? This could be caused by some blocked printer communication processes in the firewall, signal quality problem, etc. Here are some articles about communication problems and the troubleshooting steps to determine and help fix the problem at http://bit.ly/jD8fSJ.
May 12, 2011 | Lexmark Interpret S405 Wireless All-in-One...
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Dell V305 won't print
    Try changing the USB/LPT cable. If does not work, circuit board problem - circuit joint breakage - communication will be a problem.
    Jul 09, 2009 | Dell V305w All-In-One R840635AU InkJet...
    Dell Inspirion 530 won't communicate with Dell V305 printer
    The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
    Thanks,
    Abhishek
    Jun 26, 2009 | Dell V305w All-In-One R840635AU InkJet...
    Computer won't communicate with printer
    Make sure that the printer driver you are using is compatible with your version of windows. If so, open all printers in "control panel" and make sure that this printer is the preferred printer and not an old one you might still have installed.
    May 09, 2009 | Lexmark P4350 All-In-One InkJet Printer
    The printer will not communicate with my computer
    With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
    To fix a fouled install:
    (1) Uninstall the Lexmark drivers in Add Remove Programs
    (2) Shutdown the computer
    (3) Disconnect the printer from the USB port
    (4) Restart the computer
    (5) Run the Driver Installation software
    (6) Cancel ALL attempts by windows to auto install the printer
    (7) When the software asks for the printer connect it and continue
    Feb 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Communication error
    uninstall the software.
    procedure must be follow. otherwise it will not work.
    first. turn off the printer. unplugged fromt the wall.
    1). install the software with printer disconnected.
    2). turnoff the printer and connect the cable to the computer.
    3). turn on the printer.
    if you are using USB. makse sure the USB is working.
    Oct 19, 2008 | Dell 924 All-in-One InkJet Printer
    Lexmark Printer Install - No Communication Error
    Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
    is the printer in its own USB port? Some printers that "talk back" to the PC do not like to share a port so do not have it on a USB HUB.
    Apr 17, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X1240 All-In-One InkJet Printer Logo
    89 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
