Re: My washing machine will not fill with water, all...
Either the drain pipe is to low or to tight of a fit in the standpipe. There should be an air gap at the connection. Here is a link that should help Washer drains and fills at same time
If your Kenmore washing machine is having trouble filling and then drains without spinning during the rinse cycle, there could be a few possible causes.
Water supply issue: The first thing to check is the water supply. Make sure the water supply valves are fully open and there are no kinks or blockages in the hoses. Also, check the water pressure and make sure it meets the manufacturer's requirements.
Faulty water inlet valve: The water inlet valve is responsible for controlling the water flow into the washing machine. If the valve is faulty, it may not be allowing enough water to enter the machine, which can cause the filling to take a long time. It could also be stuck in the drain position, causing the machine to drain instead of filling. You may need to replace the water inlet valve.
Clogged filter screens: If the filter screens in the water inlet valve are clogged with debris or hard water deposits, it can restrict water flow and cause the machine to fill slowly or not at all. Try cleaning the filter screens to see if this improves the water flow.
Faulty pressure switch: The pressure switch monitors the water level in the washing machine and tells the control board when to start and stop the filling and draining cycles. If the pressure switch is faulty, it may not be sending the correct signals to the control board, which can cause issues with the filling and draining cycles.
If you have checked the water supply and filter screens and they appear to be working correctly, it may be necessary to replace the water inlet valve or pressure switch. If you are not comfortable performing these repairs yourself, it may be best to contact a qualified appliance repair technician to diagnose and fix the problem.
Hi, take a look at this video. You problem is probably a drain valve that is not closing completely. It could be due to debris getting stuck in it or the valve itself is failing. This video will help you figure out what it is and how to fix it.
hmmm...wool requires cold water...I'm guessing that first the hot water and now the cold water solenoid valves have become clogged with sediment. test by turning off water. then loosen the hose connection to each inlet in back of washer. then slowly open water valves and let water pour into wash tub if hose will reach, otherwise pour into a bucket. if water comes out of hose, then look for metal screens at hose connections to washer and clean those. if still no water through solenoids (after re-connecting water hoses) then may need to disassemble solenoids and clean those too.
Your problem sounds like a fill valve problem. This is what your fill hoses connect to on the back of your washer. It is an electric solenoid valve that is supposed to open when filling. However, sediments from hard water and well water have a tendency to clog them up to the point where they don't pass water any longer. Sometimes, the solenoid itself goes bad. A new valve usually runs about $20-$30. If you've checked your fill hoses and verified the household valves are working, then I recommend replacing the fill valve assembly in the washer. I hope this helps.
