Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Cannot connect to Motorloa MC9090-G to wirless network due to regulatory issues. All of my connection parameters are correct. Can someone help?
    Scholar:
  • 117 Answers
please asure yourself, that in Options of the WLAN Fusion Client (icon in the right corner) is the Regulatory set for the correct country.
To be sure, just disable the 802.11d checkbox in Fusion - Options - Regulatory.
Posted on Nov 24, 2010
  • robertczeko Nov 30, 2011
    it saved my *** :) , thanks man.
How do you enable Wireless on MC9090
If there is an 'X' on the radio icon not a '!' then it has been disabled.
To switch it on hit the wireless icon in the taskbar and select [enable radio].
If the radio fails to switch on then try a warm boot:-
Hold down the power button for approximately 10 seconds until the splash screen is shown.
If it still fails proceed with a cold boot:-
Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the fault is still not rectified then the device requires repair. Which we can help with as we have a specialised repair centre.
If there is an '!' on the radio icon not a 'X' then the radio cannot associate to an AP due to regulatory issues.
Hit the wireless icon in the taskbar and select [options], a pop up is then display, select [Regulatory] from the pull down menu. Then select your country and switch of 802.11d if not required. Save and exit
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 13, 2012 | Symbol Motorola MC9090 Mobile Computer
Got a barcode reader Motorola MC9090-G and created a profile to connect to one of our available WiFi's. When trying to connect, "Regulatory" message is displayed and no connection is made at all. The OS is...
Hello, you would need to click on the wireless icon in the right down corner and select options, then in the dropdown menu please select Regulatory please select your country. If the issue persistslase uncheck also the 802.11d option
Aug 19, 2010 | Zebra Symbol Technologies MC909X-G Series...
Can't connect wifi
do the following:
click on the mobile companion icon on the menu bar at the bottom. this is the radio icon.
click on options and from the drop down menu, select regulatory. uncheck the box 802.11d and select the country where you are.
save the options.
from the drop down menu again, select the last option called export and click on the export options button. save the default registry file and you are now sorted.
Jun 12, 2009 | Zebra Symbol Technologies MC909X-G Series...
Connecting to the internet
Hi there, this one might help since the OS is Windows mobile 5. the settings on your handheld might be quite different but still this may work. Please turn on wi-fi. There is a small icon below for wireless simply tick that and it will turn on wi-fi. Once you turn it on it will detect available wireless networks or you may simply go to Start menu and select settings. Go to connections and select network. It will give you available wireless networks. If prompted for the pass key or encryption, use the encryption set to the wireless network you're trying to connect with. Once you input the correct key you should be good to go.
Hope this helps
May 15, 2009 | Symbol MC9090 Barcode Scanner
Need WIFI Configuration manual for Mc3090. Getting error "The Profile you are trying to Connect to May not Connect due to regulatory issues"
Have to go to Fusion > WCConfigure> Options > Regulatory > uncheck ENABLE 802.11d,
I assume that Fusion is installed on all MC3090's but if not, you are looking for the wireless configuration options.
Apr 14, 2009 | Symbol MC3090
Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Jul 11, 2008 | Symbol MC9090 Barcode Scanner
Adapter disabled
Try a cold boot, then recheck your wirless settings
If that doesn't help, try deleting the Profile and adding a new one. Then walk through all the settings for wirless
Jun 27, 2008 | Zebra Symbol Technologies MC909X-G Series...
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Symbol MC3090 Error while connecting
Uncheck the "Enable 802.11d" in the Regulatory segment of the Wireless Options.
Mar 11, 2008 | Symbol MC3090 Mobile Computer
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
3,152 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
