Projector vt676 lamp installation
How do i replace the lamp in this thing?
  • beyondbent Jun 14, 2008
    so i have to pay for your free service asdvice?
  • 37 Answers
  • Turn over the projector on a soft surface. Use a phillips head screwdriver to push and realease the tab on the lamp cover. The plate lifts up.
  • Use the screwdriver to loosen the two screws holding the lamp module in place. These screws do not come out.
  • Pull the lamp module completely out of the projector. This is the lamp. You will replace with a new lamp module
  • reverse the process to install.
Posted on Jun 25, 2008
I have done above but the projector does not turn on, it trys to but then the power light blings orange and the status light blinks red for 6 times then pauses. This is a new lamp and when I put the old one back, it turns on just fine. The reason why I am changing the lamp is because its dim.
Posted on Dec 03, 2009
What does a solid red status light on a NEC VT676
This could be a number of things. When I encountered this problem it was simply a burned out lamp. If you have not checked that make sure you do that first. Also there is a safety feature on the projectors that will not let you turn the projector on until the lamp cover is back in place. You may also want to ensure that the filter door is securely in place. After you have done this try to power up the projector (it will take a few seconds for the lamp to warm up.) If the projector starts up, go to the menu and clear the lamp hours. These projectors have lamp life's that will expire after a certain amount of time, irregardless of the functionality of the bulb. Hope this helps you out. :)
Apr 13, 2011 | NEC VT676 Multimedia Projector
Power light is steady orange and lamp light is red but there is a new bulb in it. NEC VT676
If the unit will not power up it sounds like you may have tripped the lamp timer. You will need the remote plug the unit in and hold down the menu button on the remote for 10 seconds. The red light should go off and the unit should fire up.
Thanks Projector Guy
Apr 21, 2010 | NEC VT676 Multimedia Projector
Mar 02, 2010 | NEC VT676 Multimedia Projector
Nec Lt265 extremely dim
I had this same issue and it was the bulb. We had 2 of the NEC LT265 projectors so we swapped the bulbs between the 2 and it tracked with the bulb.
Mar 23, 2009 | NEC VT676 Multimedia Projector
Lamp error on nec projector
Have you changed the lamp? is so check out fixmyprojector.com
the ballast most likely needs to be replaced
Dec 16, 2008 | NEC VT676 Multimedia Projector
NEC VT676 lamp error
indicating ballast unit problem
Sep 11, 2008 | NEC VT676 Multimedia Projector
414 people viewed this question
jasbo
jasbo
