Question about Photography
Repair of a Fuji 35mm Model DL400 camera
The film will not load into the camera and the shutter will not trip.
    Scholar:
  • 185 Answers
clean all the battery contacts and be sure the batteries are good. use enough film leader so that the drive sprocket can grab the film when the film door is closed. there are no new parts for this model fuji.
Posted on Dec 12, 2008
Loaded film, but when to have film developed it was blank
The most common cause is that you didn't load the film correctly.
Hold the camera up to the light with the lens off and the back open. C0ck the shutter ready to fire and press the shutter release as you look through the camera towards a light source. If you see light briefly appear then the shutter is working and you would get some kind of image on the film, even if the shutter was wildly inaccurate. If there's no light, then repeat at all shutter speeds. If you see nothing then the shutter assembly is faulty and the camera effectively becomes a spare part donor as it's not a cost effective repair. If there is some sign of life then the camera probably just needs a good CLA service (Clean, Lubricate, Adjust). Again, not really cost effective, but you do end up with a solid and reliable camera for many more years.
Faulty film loading even catches out experienced photographers, we've all done it. In future, after you load and wind-on the film, check that the rewind crank turns counter clockwise each time you wind the film on to the next shot (you may have to turn the crank clockwise, gently, to take up any slack first).
Aug 29, 2011 | Pentax K1000 35mm SLR Camera
Rewind button on bottom of camera is stuck in a depressed state and will not release. This causes me to be unable to rewind or load film, shutter button will not cause shutter to click, film advance crank...
Sounds like your camera could use a cleaning and oiling, I'd suggest sending it off to Gus Lazzari for repair. He does good reliable work to film cameras. Hope this helps.
May 10, 2011 | Pentax ME Super 35mm SLR Camera
I took it to get the film developed and not one of my pics turned out.. is there anything i can do to fix this problem..?
1) With no film in the camera, take out the lens.
2) Open the back cover and aim the camera towards light source ( not the Sun) and trip the shutter at the different shutter speeds while looking at the shutter curtains.
3) If you see the light, the shutter is running.
4) If the shutter is running, film might not be threaded properly to the film take up reel.
Jun 21, 2010 | Minolta X-370S 35mm SLR Camera
Film release button on bottom of body is stuck in. Wont pop back out.
If you can not wind and release the shutter, the film release button will not come up.
If you can not trip the shutter, by replacing the mirror release magnet at the bottom will usually fix the problem.
May 22, 2010 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Minolta x-700
Can you trip the shutter?
If the shutter does not release, usually the camera repair shops would replace the shutter release capacitors.
May 19, 2010 | Minolta X-700 35mm SLR Camera
Shutter wont close
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
May 16, 2010 | Pentax Program Plus 35mm SLR Camera
Camera repairs
loading mechanism,gear system must be defective,so u r not able to load the film,while loading shutter gets charged,stops running,so the shutter mechnism also be chaqued.
Mar 06, 2010 | Pentax SF1n 35mm SLR Camera
Canon av1 film advance lever will not extend
The AV1 is an electronic camera that has to have a good battery for the shutter to trip. You can find the 6V battery at most drug stores or Walmart
Nov 18, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Shutter
kirstyanne00,
open the film door and check the shutter blades. did you accidentally push the blades in when loading the film? if so take the camera to a camera repair shop, the technician may be able to reset the blades while you wait.
or send it to pentax repair center for an estimate cost to repair.
Oct 25, 2008 | Pentax MZ-50 35mm SLR Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Photography Logo
95 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
