Question about Whirlpool Dryers
Dryer door pops open after running 5 minutes,close door hit start button door opens.let set 10 minutes ,run 5 minutes door pops open .dryer not overloaded. Serial #GEQ8811KTO
  • Anonymous Mar 29, 2014
    How to open door on electrolux dryer door stuck closed
    Genius:
  • 1,028 Answers
Door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
MEDC400VWO Electric Dryer won't run
Have you got power going into the machine?
NUMBER 7 is the fuse you must remove the wires to do the check
My page of this type dryer
Sep 04, 2012 | Maytag Dryers
My dryer light will not shut off even when door closed and it will not start up when in push start button it does a rapid beep
is the door switch broke?first what kind of dryer and send the model number,when the door closes it hits the door switch and shuts the light off,the dryer will not run if the switch is broke,it's like trying to start the dryer with the door open if the switch broke.
Apr 25, 2011 | Dryers
Was drying a load which strated with no problem. About 10 minutes later the unit was off and not running. Open door to check if clothing was dry and done and it wasnt. So I hit the start button and it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 18, 2010 | Asko T721 Electric Dryer
Kenmore dryer 11070882990 dryer runs for 3-5 minutes and shuts off
is the door popping open? check your door switch and actuator.
When you press the start button is there a delay/hum sound before it start. if yes it is a bad motor
can you start the unit back up after it dies or does it take a minute?
Aug 24, 2010 | Kenmore Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer won't stop running
The hot wire runs through the start button as a bridge to complete the circuit until the motor centrifigal switch closes the circuit when running. Now if you manually start your dryer and the timer doesnt advance keeping the dryer on until you open the door or advance the timer manually then the timer is good but the motor to advance the cam is faulted. The second scenario is that the dryer is off when the door is open, but when you close the door the dryer starts. With the second scenario we have a closed circuit at all times. At this point you have either a stuck start button or the centrifigal switch is closed. Usually it is the start button on this model.
Sep 08, 2008 | Kenmore 67082 Electric Dryer
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
1,715 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
