Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Blue lines on copies
I have Blue lines on copies, what is the problem.
  • 134 Answers
That shouldn't happen since it is a monochrome unit and not color.
Can you describe the lines better?
Posted on Jun 14, 2008
How can I get my scanner to copy light blue lines
Most scanners cannot copy light blue lines due to the lightwave color of the scanner lamp. This is inherit in the system and cannot be fixed. Some scanners use a lamp that can see blue, but then those don't always see light red.
Nov 03, 2015 | Office Equipment & Supplies
Konica Minolta Bizhub c754e Blue Lines after installing new machine
The blue toner cartridge or drum are damaged. First, try a different toner cartridge. This will probably eliminate the lines.
Apr 08, 2014 | Konica Minolta Office Equipment & Supplies
Why is there a black line on all documents that i print?
The 2 most common causes for lines on this machine areA) Dirty **** Glass ( This would only affect copies not internal or computer printed jobs)B) Worn Drum Unit
First make a copy off the large glass and see if you get a line still, if not try running it through the document feeder. If the line is present through the feeder but not off the large glass. Clean the small strip of glass to the left of the large copy glass and this should resolve the line.
If lines show up regardless of how or what you print/copy open the left door of the machine and you should see in the lower area a handle with a blue sticker on it. By grabbing both the front and rear handle of the unit remove it by pulling straight out and lifting slightly. If this blue/green cylinder has any tan colored lines or marks on it then the drum is worn and needs replaced.
Mar 15, 2012 | Canon imageRUNNER 1023iF Black and White...
Ricoh copier running vertical blue lines on colored copies. What's the problem?
there is chance that line appear on drum blade
try one thing just block copy during print
mean inside machine
and check ur drum by pulling outside if there is line on drum (blue) then u have to chnage drum
other wise on tranfer glass there is any dust can also make this problem
Aug 03, 2011 | Ricoh Office Equipment & Supplies
Want to copy images from notebook paper without blue lines apparent
yes, you are loking for border erase function. when you find it then look for what looks like two peices of paper side by side, you will then possible be allowed to adust the sixe of the erased area
Apr 24, 2009 | Xerox DocuColor 12 Color Copier
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Vertical blue line from top to bottom
I was told by one of you that the reason was bad drivers and to remove the software and reinstall it again. Bad advise. The blue line is a sign of dust. We cleaned the unit and the blue line dissapeared. I wasted $15.99 for bad service.
Nov 03, 2008 | HP Scanjet 8250 Flatbed Scanner
Copying data from l7i through blue tooth
well you go to that file you want to send and press the options button which is the button with the line in and select move and then copy it over blue tooth
Jul 11, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
154 people viewed this question
old marine
old marine
