Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Fisher and Paykel dd605 The flood switch has tripped and is showing "F1 with spanner" on the display turned of for 24 hr still there pumps just running . this problem happened aftr my son put cloths washing powder in it
  • 413 Answers
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
Remove the front panel by removing two "pins". There is one on each side of the drawer, and they are at the bottom and circular with a recessed tab - like an inverted slotted screw.
You just pull the tabs straight out. After that you pull the front down and out.
Drawer is removed by depressing the tab on each side and sliding the support guide back.
Use a towel to remove excess water pooling, then a hair dryer to speed up the evaporation process of the remaining water.
The FixYa Team
Posted on Jun 14, 2008
Fisher paykel dd605
F1 (or E1) is a "Flood" fault and means there is water in the bottom pan. This is beneath the bottom drawer. The sensor is in the left, rear corner of the base pan. Any kind of leak, including over sudsing or split hoses or or lid not down fully due to tall items in tub, can cause this. Remove the lower drawer, dry the water from the pan bottom, reinstall the lower drawer and check operation. If this error recurs you must find the leak and correct it.
Sep 26, 2016 | Fisher and Paykel Dishwashers
Hi, have twin drawer dishwasher which out of the blue suddenly started making a terrible noise and showed F1 on the window. Wasn't in use at the time
You have a leak in the dishwasher. The F1 alarm along with beeping sound is showing flood switch has tripped.
The inlet water hose is most likely developed a leak.
Turn the power off and disconnect water connection from under the sink.
You will have to dry the flood switch located at the base of the dishwasher housing under the bottom drawer.
Jun 26, 2011 | Fisher and Paykel Dishwashers
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
HI my fiser and paykel dishwasher is flashing f1 and is showing a spanner whay does this mean
The F1 error means a flood switch has been activated in the drawer. The spanner means you need to call a technician.
The possible causes are that the solenoid that controls the water inlet does not shut off or the sensor that detects the water level is not working. Also it is possible the water pressure is not optimum for the setting on your unit.
Nov 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
I have a fisher paykel soft touch dishwasher about 10 years old. The F1 message came on and we have taken out the inside filters and cleaned enitirely., Was working fine until it came on by itself during...
The flood sensor is located below the bottom drawer. If you take the bottom drawer out and there is water in the pan then the flood switch is probably tripped. Soak up the water with a towel and apply a hair dryer towards the rear left corner of the cabinet. The flood switch is part of the Mains Filter control board and should not be messed with (even with the dishwasher unplugged)... There is an underlying problem that caused the F1 fault and you should have a technician look at it.
Jun 17, 2009 | Fisher and Paykel 24 in. DS603H I Built-In...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
613 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
