Question about Panasonic CQ-C1100U CD Player
I have a panasonic cq-c1110u and i am trying to get me amp to work and i cant seen to find the remote wire witch one is it ?
SOURCE: CQ RDP162N
i can get a general wiring diagram for now need to look into it sum more
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Posted on Dec 31, 2008
etirbynnor
  • 655 Answers
SOURCE: Panasonic CQ C1100U amp output?
Yes, the Panasonic CQ-C1100U can be connected to a 2-channel amp. It has a single set of preamp outputs. I'm attaching an image of the connection shown in the Panasonic user manual. The appropriate connection is the one without the dashed line. The dashed line showing a 2nd set of outputs only applies to the 1110, 1120, and 1200 models.
Hope this helps. If it does, please rate as "FixYa". Thanks!
Posted on Mar 30, 2009
SOURCE: Panasonic CQ-C8400U CD turns itself off after 9-10 mins
Hey did you ever get this problem fixed? My deck just started to do the exact same thing.
Posted on Jan 07, 2010
  • 6 Answers
SOURCE: panasonic radio wiring
it maybe a speaker
Posted on Apr 25, 2010
brianw74
  • 400 Answers
SOURCE: how do i hook up my amp power wire to my panasonic
Your power amp wire (positive (RED) ), should be hooked up directly to your battery....THe ground wire should be anchored to a bolt in your trunk (the short the distance the better), Make sure ground is getting a good bite on metal (no paint etc)....Only thing you should have hooked between your amp and radio is the rcas and your remote wire (blue).
Posted on Oct 07, 2010
I am trying to hook up an amp to my panasonic cq-c300u but i cant find the remote wire in the back. does it even have one? and if not is there a way to add one?
If your stereo doesn't have an option for amp cut the RCA wire that you're going to use and connect it to the output speaker wires at the back of your stereo. You can also use crossovers.
Apr 07, 2011 | Panasonic CQ-C300U Car CD/ MP3 Player
How do i hook up my amp power wire to my panasonic cq-rx100u
Oct 07, 2010 | Panasonic CQ-RX100U Car CD/ MP3 Player
Trying to wire in a 92 chevy s-10
Buy a wiring kit for your vehicle (available at walmart, autozone, etc) It takes the guess work out of which wire is which coming out of your dash.....Panasonics wiring is standard to that of other cd decks....Red=ignition Yellow=memory or battery Black= ground Blue=remote turnon for amp or antenna, Orange=illumination, Then the green, white, grey & purple wires are speakers (positive and negative).
Sep 19, 2010 | Panasonic CQ-DP133U CD Player
CANT FIND MY MANUAL! DONT KNOW W/C WIRE TO POWER UP MY AMP? TRYING TO HOOK UP AN AMP IN MY CAR
Blue/White Stripe = External amplifier control power lead
Blue = Antenna control lead
Red = ACC power lead +12 Volts
Yellow = Battery lead Constant +12 Volts
Black = Ground lead
Here is the manual for the Panasonic CQ-C1300U CD Player.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 27, 2010 | Panasonic CQ-C1300U CD Player
What are the 2 blue and 1 black wires for
amplifier remote turn on and if your car has a power antenna
Jan 08, 2010 | Panasonic CQ-C1110U CD Player
I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Aug 19, 2009 | Panasonic CQ-C700U Car CD/ MP3 Player
Not working
If you have a short anywhere it could have blown the amp. I've seen that happen when one of the speaker wires was exposed and touching ground.
Jun 05, 2008 | Panasonic CQ-C7301U CD Player
Panasonic cq-c7401u
If you using external amplifiers with you system;check your remote wires.
You may be using the wrong remote wire to turn you amp on.
There are two remote wires,one is for pwr ANTENNA(BLUE ONLY),this wire cut the pwr out when you insert a cd.
The other wire is the REMOTE TURN ON(BLUE/WHITE STRIPE)this is the one you need to connect to the you amp.
LET ME KNOW IF IT WORKS.
Dec 22, 2007 | Panasonic CQ-C7301U CD Player
Panasonic CQ-C1100U CD Player Logo
137 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
