Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Kenmore 22 side-by-side
I just purchased an Kenmore 22.0 cu.ft and the water machine of it not connected how do I go about connect that water line Ican see on the bottomof the rack?
  • 833 Answers
You should have instructions from Sears that came with the box. Generally, there is a fitting made of brass on the lower part of the back of the fridge. It is generally labeled. Get a kit to connect to the supply...sold at Sears and other appliance/hardware retailers. Generally, they come with some instructions. Find a cold water line of 1/2 inch diameter and make sure it is pretty clean...no dirt/dust on it. Use the clamp/valve unit. Install it on the tubing until it is tight. Tighten the valve according to directions to puncture the cold water line. Install the tubing on the valve and using a small container, turn on the water just a bit to flush the line. Install it onto the fitting on the fridge. If you're making holes in floors or walls to pass the tube through, cover the tubing end with tape when passing it through the wall to keep out the dirt. Tighten the tubing fittings just enough to stop any water drip. Overtightening will cause leaks.
Posted on Jun 19, 2008
Water inlet valve for kenmore refrigerator
Make sure the switch in the door is functioning first. Plastic parts fail to allow the switch to contact the paddle. The inlet valve is where the water line connects to the fridge. You can get replacements at an appliance parts store . There are many online parts stores too.
Jun 24, 2014 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
I have a kenmore ref and last night the floor was flooded was cause i had to turn the water off what could be the problem serial# 106.54536400
Under the front of the fridge behind the metal kick, there is a drip pan, these pans usually have a heater to evaporate the water in the pan. To get a low eer rating they wont hook up the pan heater until after the consumer has purchased the unit, check that the pan heater is connected. and you should be good to go. If your not sure, you can empty the pan with a wet vac until you can get the pan heater working.Good luck Behind this kick there also is the water line hookup for the icemaker and water dispenser check to make sure your connections are secure
Sep 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS5VHAXWY00 25 cu. ft. side by side contour door - in door water has stopped flowing. Refrig is 6 months old. Water still flows to ice maker.
when you push the button inthe front of the machine it should give power to the valve in the back of the machine .check the valve in the back of the machine where the water line connects to make sure there is no blockage in the line next thing to check is if your getting power to the valve on that side of the valve that the water is connected
Apr 28, 2010 | Refrigerators
Age of Kenmore side by side refrigerator
Brand: Kenmore
Type: side by side refrigerator
Country: USA
Model: 106.58123700
Serial: HRW2754229 This product appears to have been manufactured the week of June 30, 2008
for anything like that next time on any other appliance check out this link by clicking it directly
http://www.appliance411.com/service/date-code.php
Apr 01, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Connecting the fridge to the water point
you need to connect your fridge to a constant water supply such as a water main make sure it is a cold water line that you connect to. good luck peyton
Feb 02, 2009 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Is there any water problems in burtonsville i thougt the pipe broke.
If it is like my Kenmore, the water tube connection at the lower edge of the freezer door hinge line, may have come loosened by opening and closing the door. That tube provides the water source for the in-door chilled water outlet. Just tighten the connections.
Jun 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Refrigerators Logo
121 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
Fred Sops
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
