Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Board Repalcement Hi...Do you know a place other than Mitsu or Sears for PCB outright purchases? Thank you in advance... -MetalDad
    Genius:
  • 3,422 Answers
HI,
You can try partstore.com or appliancepartspros.com
Posted on Jun 14, 2008
Mitsubishi WS 55513...
sounds like the power supply board is unhappy
Mar 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Power pause error lights on and can not clear
You have a bad Main Logic Board and it needs to be replaced or fixed. I can supply refurbished Logic Boards at a good price outright or exchange. I can also repair your logic board at about half the price you would pay for a refurbished one. I also carry a 30/day warranty for a purchase and a 90/day warranty for a repair.
Please let me know if you have any other question.
Thank you.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
AOL IM: RORYMRP
Jun 15, 2009 | Zebra Z4M Printer
Lightning strike
Hello bkindle.....not a boat anchor YET!!!! Had similar problem with WS-55513 and it turned out to be a faulty DM board. There are 4 capacitors on the board that may have blown. If yo can solder, it is a pretty easy repair. I purchased a PDF manual for mine online to get familiar with the model.
Otherwise, you can expect to pay between 275.00 for a repaired board OR between 350.00 and 450.00 for a replacement board from Sears or Mitsubishi.
Hope this helps. I know it is frustrating but be patient.
Good Luck - Richard (MetalDad)
email: PentiumDreams@aol.com
Jun 12, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55513 blinking power light
The infamous flashing green LED problem is usually due to a failing or faulty DM board. I purchased the PDF manual online and was able to locate and remove the components as necessary.
If you can solder, and are semi-proficient with electronics it is 4 bad capacitors on the DM board...
Otherwise there are facilities that can repair your failed board for about 275.00 or replacement of the board is between 350.00 and 500.00 buck USD.
Good Luck with your repairs....
-Richard (MetalDad)
May 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Short Protect Problem
The problem is usually a failing or faulty DM board which can be fixed with replacing the 4 bad capacitors...OR...if you cant solder it yourself, a repair facility may charge 250.00 or so and takes about a week turn around time.
The other option is buying a replacement board either from Sears or Mitsubishi from 350.00 and up.
Hope you have good luck. If I can help anymore, let me know.
-MetalDad (Richard)
May 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Rechecked the conections and still
well..that's interesting...before you begin, have you determined a source for replacement components? I'd be hesitant to do all that work, NOT knowing if there are readily available form fit function components for it. Don't assume that overseas manufactured appliances have a ready distribution system for spare parts.
Mar 19, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS55513 ---Flashing Green LEDs...and now NO POWER.. Hi...got the entire board / chassis out of the TV shell. Going to start checking individual components, starting with the mail power supply...
start by pulling the DM board (looking from the back it is standing upright on the left side in a metal chassis) and you'll probably find 4 bad capacitors (bulging on the tops is a good indication, If i remember correctly they are near the top right corner)
you can buy replacements here..
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P13119-ND
Fixed mine this way several months ago..still working like new.
Good luck
Mar 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Checking electrical components--Mitsu WS 55513
hello the power supply board is to the right of the set . when you are looking at it from the back.!!! how you will know is the fly back transformer will be there, it will be black in color & will have 3 to four red wire's comming out of it.!!! there are 3 fuse on that board . !!!! they look like a regular fuse .!!! but just smaller in size.!!! they should not be hard to find.!!! you might want to get your self some glasse's to help your self see better.!!! well a"good luck" hope this help's you.!!
Mar 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
www.chrisandnat.com/projects/blinkingtv/blink.htm
Also,check three 4 amp surface mount fuses on trace side
of board.............T.
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
