Question about Dell Dimension E310 PC Desktop
Dell dimension e310
My ethernet card dont work becousse of that i cant instoll my router
  • Zdaddy Feb 11, 2009
    My ethernet controller, PCI simple communications controller, SM Bus controller, and video controller (VGA compatiable) drivers all do not work.  there is a yellow ? next to all of them. It says the drivers are not installed, but i cannot reinstall them off the disk.  And since these drivers do not work, i don not have access to the internet.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
What you need to do is install your ethernet card first. The card usually comes with a disc with the drivers and utility. Make sure you get that done to get it out of the way. Next you need to make sure the router is connected properly. If you have the installation guide for the router, check the lights. If it's properly connected, there should at least two green lights and one amber. The amber light should indicate theat you have no internet connection yet. You may want to check the proceedure about accessing the router. Usually typing the homeportal in the address bar on Internet Explorer. If you don't have the installlation guide for the router, download it under support at the manufacturer's website. The important thing to keep in mind is to make sure the ethernet card is installed properly meaning the drivers and utility(if any) are installed, and all it is is that it just has a red X on it telling me i don't have internet connection. From there, all you need to focus on is the router installation(physical), then follow the proceedure to access your router. Well i hope you fix it.
Posted on Jun 14, 2008
Wireless connection for e310
http://www.ebay.com/itm/100-TESTED-GUARANTEED-DELL-DIMENSION-3100-E310-MOTHERBOARD-JC474-WJ770-FAST-S-H-/321044602266?pt=Motherboards&hash=item4abfbfdd9a
The two long White expansion slots on the motherboard, are PCI Slots.
http://en.wikipedia.org/wiki/PCI_local_bus
If you have one available you can use a PCI Wireless adapter card,
(PCI Wireless Card);
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4389486&CatId=2701
OR,
A USB wireless adapter,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=357235&CatId=2704
Make sure your router is a wireless router, AND either it has a built-in modem, or your internet provider has provided you with one.
There are different setups, and different types of wireless.
Most common are DSL and Cable.
You can also go the satellite route IF available.
Regards,
joecoolvette
(A wireless N capability; wireless adapter card, or USB wireless adapter, has a range of 150 feet )
Regards,
joecoolvette
Jan 06, 2013 | Dell Dimension E310 PC Desktop
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
May 28, 2012 | Dell Dimension E310 PC Desktop
I have a Dell Dimension E310 with the power button flashing amber. I recently replaced the power supply due to an electrical storm, good reason to suspect the power supply. But the only way to get past...
i suggest using a PCI ethernet lan card with drivers cd. this should allow the bypass of the integrated connection to be that of the newly installed device.
Jan 17, 2011 | Dell Dimension E310 PC Desktop
Dell dimension e310 i have two soundcards on my computer top /bottom i know the top card is blown so i want to turn the one at the bottom on but how
Head into your device manager. there will be a product name for both sound cards. Click on the sounds card wanted then a pull out will come out with the sound card wanted. Right click to disable the blown sound card. then right click to enable the sound card you want
Jan 19, 2010 | Dell Dimension E310 PC Desktop
Cant get on the internet
The longer the cable, the slower the connection.
It should work with the cable as it is not "too" long.
I would try turning the modem and router off for one minute and then turning back on.
Jennifer
Dec 29, 2009 | Dell Dimension 2400 PC Desktop
I need a ethernet controller for dell dimension e 310
please visit DELL SUPPORT.COM .....enter your machine model and wow................. you get what you want
May 18, 2009 | Dell Dimension E310 PC Desktop
No ethernet controller drivers
Here is the link for your ethernet card. http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=5&impid=-1&servicetag=&SystemID=DIM_PNT_P4_3100&hidos=WW1&hidlang=en&TabIndex=
From here, you have 2 links available that pertain to your problem. The 3rd link looks like your anwer.
Apr 16, 2009 | Dell Dimension E310 PC Desktop
Network cable unpluugged
Call your ISP to make sure it is not on there end plus they can help you with support. Let me know if this works If not give me more info about how you connect to the internet. Please rate me mysleuth
Mar 24, 2009 | Dell Dimension E310 PC Desktop
Dimension E310
Im not sure if you are asking for the E310 drivers or the 4600c drivers, so I'm sending you the link to download drivers for both the systems.
http://tinyurl.com/2jpgqs (Thats for E310)
http://tinyurl.com/5jzwtd (Thats for 4600c)
All the best fixing your system
Mandeep
Jun 15, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension E310 PC Desktop Logo
745 people viewed this question
Alun Cox
