Question about Maytag Kitchen Ranges
The lower latch of my maytag oven (elecrtic 30-inch Wide Free-standing Double Oven Range) is not closing and on the display is the code F9:-5
  • 868 Answers
Check the door latch and replace it if you can't repair it.
Posted on Jun 14, 2008
I have a code 5ab on the panel my model nuber is MGR5775QDS its a 30 inch free standing gas stove.
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2348-maytag-oven-weird-error-code-5ab.html#ixzz1GLM0d1gp
Mar 12, 2011 | Maytag MGR5775QDS Dual Fuel (Electric and...
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
Our maytag 30-inch wide free standing range is about 4 or 5 years old. We've had no problems since we've had it - until yesterday. The short story is that when I press the "Bake" button, the oven won't...
Hi-  The problem you describe sounds like failure of the igniter for the lower burner. The part can be accessed by removing the drip pan at the bottom of oven. Resistance should be more than 4ohms, but if it doesn't glow at all it is probably broken. The part normally runs 40-75$ and is easy to install. Let me know if this info is helpful, have more if needed. - Thanks- Ed
Mar 16, 2010 | Ovens
My Maytag Gemini range has a F9-4 code when trying to clean?
Hi There
I have found this code for you and hope this is helpful.Let me know how it goes.
F9 Door latch Check door latch components.Best Regards Richard
Jan 06, 2010 | Maytag Gemini 30" Self-Cleaning...
After a oven self cleaning the range would display and error code of F 1-A and the lower oven will come on then turn off. This is a Maytag range model #MER6550BAW Sn. 14367494CC
F1:-A Latch Switch, Upper Check door latch switches, replace if necessarythis should help u let me know if u need anything else
Dec 04, 2008 | Kitchen Ranges
Kitchen Ranges Logo
93 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
