Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
I got the above KOGI monitor from a friend with missing Power Supply and computer cable. I need the information power supply and connection cable for monitor KOGI L7EH-TA Model L7VH and Type = EHTW, where can I find these missing parts??
Thank you very much.
  • hopier Aug 08, 2008
    Solved the problem by taking the monitor to compuer shop to match the right power cable. Thank you.
  • oscarthebull Oct 02, 2008
    I have the KOGI L7EH-TA I live in the Tampa Florida area. I have been to all the 'Big Box' computer stores and none have the power cord. Can some one out there help me.
    Genius:
  • 1,011 Answers
The power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Posted on Aug 08, 2008
A friend gave me the Kogi 17 eh-ta ko 17 in Flat panel LCD monitor. We got it installed and the screen has a pinkish tinge to it. Don't have the manual and would like to find out where the tint control is....
communikay, The pink tint means that the cold-cathode-fluorescent-lamps are just about at their "end of life" and will need replacing!! I would be surprised if it lasts another month or two and then you might need to rebuild the inverter circuit that also might die from being overstressed due to the fact that old (many "ON" hours) CCFL's draw excessive current making the switch-mode-power-supply/inverter circuit work harder to light the lamps? 12fixlouie
Apr 03, 2010 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Need driver for L7EH-TA Kogi Monitor
nee driver for L7EH kogi monitor. built in speakers don;t work
Nov 22, 2009 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi monitor will not come on.
Try going to your local radio shack and matching the power requirements with. your current supply with the one at the store. Make sure they match
Nov 26, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi l7eh-ta ko 17 in
It looks like your power supply is shutting down (terminal overload shutdown) due to excessive current consumption. You need to get a power supply that meets the voltage and current requirements of that monitor or greater current reuirements.
Sep 03, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I need a power supply for my Kogi L7EH-TA monitor
I would not recommend this because my monitor will probably burn up from doing this but; I just lost my power supply last night and I took a power cord from my seagate external 500 GB hard drive which has the same pin size plug in that goes into the monitor and plugged it directly into the wall. I assume that the external hard drive uses the same ac to dc converter although it looks just like a cord with no inverter capabilies. Not sure of the amps though and this could burn up the monitor completely. Works for now.
Mar 04, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Power
Is there a question somewhere in that statement? So what it takes a power supply, so does mine. Are you missing one, and need to know which one to get? You can buy replacement and generic power supplies off of ebay. The output should be 12VDC. Not sure how many amps you need from the power supply, but a 4 or 5amps should do fine.
Now you just need to make sure the plug is the correct size and voltage orientation. This sounds complicated but it is not. 99% of the time the tip of the plug is +12VDC, and the other part is ground. Some ebay auctions will even list which monitors there particular power supply will work with.
Nov 14, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi
Power supply for what exactly? The monitor plugs the wall outlet. Do you mean cable?
Oct 26, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Need to replace the power supply
Ebay has power supplies, I bought mine from there.
Sep 11, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
228 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
