Question about SanDisk Sansa m230 MP3 Player
Not Enough Room For Music DB.. Please Free 8MB? ...HELP
I Think I downloaded Too Many Songs Onto My MP3 And Now It Deleted all My Files. So Now When i turn it on it loads up then says " Not Enough room For music DB. Please free 8MB". I Deleted All My Songs And Formated It, but it still says The same thing. And It Says 67MB Left On My Windows Media Player.. So I Dont Know what to do know..
  • 8,596 Answers
Get the firmware upgrade from SanDisk's website:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 05, 2008
It says MUSIC DB full.Free 8MB...even though there
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
If you want to delete any of the files there then follow the directions below:
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 12, 2009 | SanDisk Sansa m230 MP3 Player
Says not enough space when there is nothing in the mp3.
just format it then put all music in again or just sync
Nov 10, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa
try plugging it into the computer and viewing at as a hard drive, then you will probably be able to see everything on the player
Mar 19, 2008 | SanDisk Sansa m240 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Not enough space for Music DB, please free 8 MB
The Sansa m250 requires a separate folder to load your songs to in order to achieve the full 2 GB. Set your USB to MSC. Plug it into your computer. Create a folder TUNES. Then drag and drop your mp3 or wma files to this new folder.
Jan 28, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
PLEASE HELP I CAN"T LIVE WITH OUT MY SANSA
"Please free 6MB for music DB" means that there is not enough MEMORY for the MUSIC DataBase. Therefore, you cannot see the music on your device.
To resolve this, you need to delete music until your device is less than 6MB of being full.
Generally 10 to 15 songs should do the trick.
Best of Luck,
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
Not enough space for music db
Your device has too much music on it.
You need at least 8MB free in order for it to build the "database".
Connect the device to your computer, delete 10 songs, then re-start the player and you should be back to normal.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa m230 MP3 Player
No files
The device needs at least 8MB to build the Music DB (database or GUI). You need to manually delete some files from the device. You will need to connect it to the PC and open it in My Computer>Device Name>Music Folder. Delete a few songs, disconnect and restart the device. You can add to the question if you need more assistance. Best of Luck.
Sep 30, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
145 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
