Question about Panasonic KX-TG1033S Cordless Phone
Cordless phone can't release mute
All 4 phones are stuck on mute
Posted on Feb 02, 2009
    Problem Solver:
  • 12 Answers
Try new batteries
Posted on Jul 15, 2008
How can I get my proscan led tv out of mute
Press the 'Mute" button at the remote control; Once. The mute function should be released. If not, the main digital board has the fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 16, 2016 | Proscan Televison & Video
HOW DO I TURN ON THE AUTO MUTE ON A COBRA ESD 8285
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Jan 27, 2016 | ESD-8285 Radar Detector
How do I do an automatic code search on a ge unigersal remote control model 24993 - v4
1 manually turn on device(TV, VCR,ect. Be sure batteries are good in remote.
2 press and hold the CODE SEARCH button until the red indicator stays on,then release Code search button.
3 press and release mode button (TV, VCR, ect) the red indicator blinks,then stays lit.
4 press channel up( up to 300 times) until device changes channel. The red indicator blinks,then stays lit.
5 Press the Mute button release to lock in code
Tips if you go pass the code use channeldown when channel change hit the mute button and release it to install code.
Apr 12, 2015 | GE Televison & Video
Lcd tv repair problems
reset to factory settings presing (MUTE+182+POWER ) on the remote control and choose factoy reset.
this must be done with the tv off.
Aug 13, 2014 | Samsung Televison & Video
Trying to program a direct tv remote to work with my 46" lcd, Vizio tv. Have tried the codes provided, but they don't show when I type them...not sure if actually being entered. Or, maybe have...
1 Vizio tv.code 0864 OR 10885 OR 11756OR 10178
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Oct 03, 2011 | Televison & Video
The sound on the TV Model PBT-26000W is not good. There is a symbol top center of the TV (not mute-bottom) with crossed speaker. How ca I remove this symbol and get normal sound.
Use the remote control,look for a button said MUTE.Push the button on the remote to release it.Or push the volume button + - to release the volume control.
Oct 11, 2010 | Prosonic PLTV-30 30 in. HD-Ready LCD...
No sound
hi! press the audio setting and set on the audio set on
Sep 08, 2009 | Jensen VM9020TS Car DVD Player
Handsfree mute will not turn off
The handsfree.mute key is turned off by the release (Rls) key.
Aug 19, 2009 | NorStar M7208 Corded Phone
Tv remote src350a motorola
Turn on tv press and hold the select button and mute. Hold until LED button lights up. Press up arrow, release, press and release. The light will blink each time you hold the button. When tv turns off press select to store the code. Changeing the stream press and hold mute and select release when light comes on. Press and release the A key. Enter 0 ro run stream one enter 1 for stream 2 and 2 for stream 3
Mar 05, 2008 | Motorola Televison & Video
Panasonic KX-TG1033S Cordless Phone Logo
222 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
