Audio out of sync when i record a video on my archos 705 and then transfer it to dvd
I find the problem may be with the Top-Box ,not getting a clean signal....This is DEF true if u are using a High Def Top Box.
Best solution is to make all component`s free from each other.( Conection`s etc ) as much as pos. + Use a signal booster.
So it`s all down to the Aerial configeration.
Good Luck.
Posted on Aug 25, 2008
Can you advise where I can buy a replacement screen for my Archos 705
Hi
You can order the screen for the Archos 705 from this link---
Archos 705 replacement screen
Link 2
Hope this helps...
Daniel
Aug 28, 2010 | Archos 705 WiFi Digital Media Player
WHEN PLAYING DOWNLOADED VIDEOS ON MY ARCHOS 705 THE SOUND IS BARELY AUDIBLE CAN I FIX THIS?
The videos you are watching have bad audio guality, you need to get a video with good enought audio.
Apr 17, 2008 | Televison & Video
Occasionally when I transfer a dvd to my Archos 5 (firmware is upto date) I get a crackling sound and the sound is out of sync with the picture. Some dvd's work fine, then it doesn't. What can I do to fix...
I would personally (if not under warranty) open the case and look for cold solder joints and if any solder points don't look normal, go ahead and resolder those. Follow the board's trace from the audio plugs and look at those solder joints.
Nov 14, 2009 | Pinnacle Video Transfer
No Audio on Video Clips from AV400 playing on Laptop Win Med Plyr
is very likely what is your turn to review programs carefully mind because that is a bad configuration
Aug 22, 2009 | Archos AV400 Digital Media Player
Can you connect an archos 605 to a bell 9142 pvr
Archos Dish Network Plug-In says:
  •  Quickly transfer hours of your favorite TV programming from select DISH Network DVR receivers and enjoy the shows you watch every day- on the go.
  •  DISH Network customers with ViP622TM and ViP722 TM DVR receivers can enjoy this next generation of PocketDISH service with Archos 605 WiFi and Archos 705 WiFi models
  •  This plug-in is free for DISH Network Customers.
  •  Not a DISH Network customer? Find out more at www.dishnetwork.com and get the most out of your Archos player today
  • Jan 24, 2009 | Archos 605 WiFi Digital Media Player
    Just got Archos 5 goes into error 101...
    Hi there, these instructions are for the archos 705 but they are the same for the 605.
    A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
    B) The Archos 705:
    1- Connect the unit to its power source.
    2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
    3- The recovery mode will start (the screen that asks for repair or format etc…)
    4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
    5- Now that you are on "Repair" select it to validate your selection
    6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
    8- Wait until Pc should recognizes your Archos (around 5 seconds)
    C) Computer
    1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
    D) On the Archos 705:
    1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
    2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
    3- DO NOT DISCONNECT the power cable until the process is finished
    4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
    5- Press on/off button to reboot
    Your unit should restart with a fresh repaired, updated system like day one.
    Jan 21, 2009 | Archos 605 WiFi Digital Media Player
    Archos 705
    Make certain the cables are going into "in" sockets, The Red (right audio) White (left audio) Yellow - video. If the TV has a scart socket on you can get a scart to phono leads with the same combination sockets red, white, yellow.
    Oct 03, 2017 | Audio Players & Recorders
    Archos 700
    1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
    You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
    Oct 09, 2007 | Archos AV700 Digital Media Player
    Voice out of sync on transfer to computer
    hiya, your camcorder i presume must use MPG2 and audio with 48k. if u r using adobe premiere to store, then u have to choose the 48k audio format. if ur using any other thing to store, i would recommend final cut pro... pls correct me if i'm wrong.... happy troubleshooting
    Feb 28, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
    Televison & Video Logo
    73 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
