Question about RCA HD52W59 HDTV Projection Television
SCREEN CONVERGANCE IS WAY OUT OF WACK, THE OPTION FOR ADJUSTING THEM HAS DISAPPEARED OF MY MAIN MENU. What do I need to do?
  • jovanlopez08 May 11, 2010
    Should i try it with the eBay fuse? Thanks.
    I just read in another blog post that the fuse 'FL231' was changed, and then the television seemed fine (the rgb colors were aligned) but the tv turned off every 5 min. Does it have something to do with the new fuse, or the installation, is there a safe way to install this fuse, because i found one in eBay. Thanks!.
  • RCA Master
  • 8,617 Answers
Sounds like you have a RCA television If so replace fuse FL231
Posted on Jun 14, 2008
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59YX35
just change the picture tube.
Dec 09, 2007 | RCA HD52W59 HDTV Projection Television
Modle model hd52w67yx66 lost convergance pic has three colors in main menu no convergance option like when new open for sugestions tuner and sound ok
Thats a easy and inexspensive repair. www.tvrepairworld.com has the RCA repair kit called "ITC222 and ITC222A convergence option missing repair Kit" The kit contains the components and the CD with detailed repair instructions.
Dec 22, 2009 | Televison & Video
53inch RCA big screen tv , double vision...you asked me Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if...
Just press menu and then scroll down to settings and then under settings menu you should be able to see convergence. If not its disappaeared and thats a easy an inexspensive repair.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Convergance adjustment
if the convergence option is missing from the on screen menu you will need to replace DL231, CL230, and FL231 to restore the option. You can get the parts and instructions at the following link for less than 20.00. They also most likely have the original remote for your set also. Leave them a email to inquire.
http://servicemanuals.vstore.ca/
Jan 30, 2009 | RCA D52W19 52" Rear Projection Television
Adjusting the convergance
On my 55 inch rear projection Samsung, there is a menu option to adjust the convergence. There is a manual as well as an automatic option. It is easier to do with the remote control. My Samsung remote has a button called 'perfect convergence' or something like that. you can also get to it from the menu tree pushing the menu button on the front of the set. You need to scroll through all the options to adjust color, contrast, parental control, etc. You should find it.
I assume the same is true on the 37inch samsung.
How old is the set? A number of samusng sets have problems with two large IC's that tend to burn out. This causes the symptom of colored shaddows, tend to be worse the further away from the center of the screen. I just finished doing the repair to my set. If you cannot adjust the convergence, that is most likely your problem.
May 13, 2008 | Samsung HCN473W 47" Rear Projection...
Green convergance problem
Sounds like a convergence amp failure. Depending on model, there may be 1 or 2 large Ics. Due to the delicate soldering involved, a tech should change these amps.Often the old part numbers have been upgraded, and small value resistors may need to be changed also.
Apr 23, 2008 | RCA P52939 52" Rear Projection Television
Color bending
Go into the menu and look for Screen Convergence. It may also have an auto convergance option try that first. If it gives a suto error or you cant adjust it manually the convergance IC's may be bad or a component on the convergance board.
Sep 15, 2007 | Sony KP-51WS500 51" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
226 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
