Question about Frigidaire ATF6000ES Front Load Washer
How do I get rid of musty smell from my Frigidaire front load washer?
    President:
  • 1,430 Answers
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump.
Posted on Nov 04, 2010
3 Suggested Answers
  • 197 Answers
SOURCE: How do I get rid of the musty smell?
If you know someone who owns a bar, ask them for about 1/2 pt of line cleaning fluid. Start your machine on a 60o wash (empty) and as soon as the water starts flowing into the powder drawer, slowly pour the line cleaner into the water flow. Let the machine go through it's normal cycle, then run the same cycle programme as soon as you can (immediatly if possible) using clean water. Following this action, get your finger and rub it along the inside of the drum, if it's squeekly clean it's solved, if it feels slightly slimely, run the water only wash again the completly to remove any further residue of the cleaner. The smell should go. Let me know how you get on, Regards Dave.
Posted on Jul 17, 2009
  • 12 Answers
SOURCE: How do you get rid of the musty smell in a front
Good Info.
clean your washer once a month by using 3 tablespoons of Cascade or Electrosol dish detergent poured straight into the soap dispenser. Enzymes in the detergent eat up the scum and the pumice in the dish detegent scrapes off the residue that may be on the pvc behind the drum, that may be in the drain hose AND in the pump. Follow with one cup of bleach poured directly into the soap dispenser and once again, choose a hot fast wash. This disinfects the parts of the machine. Leave the door open a bit after using and remember to Lock the controls after you do the washing and unlock it when you need to do a new load of laundry. Safer that way.. noone can start the machine.
Use vinegar instead of fabric softener. Fill up the fabric softener dispenser with cheaper vinegar, like Four Monks from costco... softens, anti static, removes soap residue and grease from your clothes etc.
Posted on Aug 13, 2009
What can ido to get rid of musty smell
Here is a tip that I wrote about that...
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
May 19, 2010 | Hotpoint WMA40 Front Load Washer
There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
Hi.
The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
The only way to remove is by replacing the door seal.
If you try bleach etc then it will cause the mold to get worse.
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Jul 17, 2009 | Frigidaire Affinity ATF6000F Front Load...
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
I have the same problem with my machine. Also a frigidaire. After speaking with many repair people apparantly this is a common issue. With mine the gasket that seals around the door has separated completely from the machine and you can literally lift is away. If you pull it back you can run your finger along the metal of the machine and lift of soft black mold. I am in the midst of trying to get my machine replaced with another brand under warranty. This has actually caused severe allergic reactions to my family and took over 6 months to find.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
what kind of washer?
all front load washers get this issue
the way to get rid of the smell is by doing an acid wash to your machine
set the washer to the highest temp setting (sanitize would be best)
mix in 1/2 to 2/3 cup of javex or white vinigar, either one will do it
run your washer through the longest cycle possible with no clothes in it
may need to be done more than once. and up to once a month
the smell is caused by leftover detergent and leftover fabric softner gathering on the interior shell and in the rubber boot at the door.
front load washers do not require much detergent at all, and even less fabric softner.
be careful on how much of these you are using, more is not better
this will help prevent the odor from comming back
as well when laundry is not being done, the front door should be left open a bit to allow air movement in the washer.
hope this helps
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer has a really bad smell like musty if i leave the doors closed or if I leave clothes in for a couple of hours is this a probem with them
hi there,
the musty smell is from the door boot or gasket. deposit from clothes and detergent get trapped in there and have nowhere else to go. i would recommend purchasing Washerfresh tables to get rid of the deposits. they are available all over.
Dec 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
147 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
