Question about Uniden Cordless Phone
"FL" on my display, having occurred while I was away
What does this mean? What should I do about it? Could not find any info in Owner's Manual (though maybe I didn't know how to find it there!)
Would like to make it go away, after I find out what it means...
Worrisome?
"FL" on the display apparently means "full" and apparently occurs when the message-recording capacity of the system can accept no further messages! So when you hit 20 or 21, you need to get rid of some to make room for more coming in. Well, duh! --On the other hand, this really should be addressed in the Owner's Manual, which makes no mention of same (that I could find).
Posted on Jun 14, 2008
Receiving error code FL on washer display.
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Dec 07, 2012 | Crosley CW6000 Front Load Washer
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Does the machine have to be full to function properly and what does FL mean.
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#!@
May 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Will not run has fl on display
Flood Condition:
Dec 28, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does FL mean on the rinse and spin extend cycle?
Flood Condition:
Oct 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
MY WASHER IS BEEP AND DISPLAY FL
FL means flood condition
Solution: "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Jul 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore Calypso washer is saaying LE and FL. what does this mean?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@%^
Jun 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
FL code constantly flashes, how do I reset?
Flood Condition:
May 23, 2009 | Kenmore Washing Machines
We have an FL error - all the manual says is to press stop/cancel...it's not working. How do we fix this?
Flood Condition:
Jun 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Uniden Cordless Phone Logo
218 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
