Question about HP Computers & Internet
My computer opens up stating "updating stage 3 of 3 0% don't shut down your computer" which has happened many a times but it doesn't get past 0% and shuts down, the same thing happens updating and shuting down over and over. The last time i used the computer my norton was updating and needed the restart but i was running lating for work and just shut it down instead.
    Problem Solver:
  • 6 Answers
Hmm.. this sounds like a virus to me, but i'd need to see a screencap to be sure.. (which obviously is a problem!)
either that, or corruption within system files.
If you are running windows XP - run a repair install, there are many good intructions over the net if you get confused but basically all you have to do is use your original windows cd, boot from it using prompts in the BIOS when your computer boots up and follow the prompts.
be warned, do NOT reinstall windows completely UNLESS you have backed up all your files, drivers etc.
Apologies for the vague solution, it's a little hard to identify the problem without seeing it sometimes =]
may I also make a recommendation - do not use Norton as an antivirus, it has a rather heavy load on systems and often causes problems of its own.
I'd recommend Nod32 Antivirus instead =]
Good luck!!
Posted on Jun 14, 2008
    Guru:
  • 1,342 Answers
Try tapping the F8 key while the pc is rebooting to get to the boot menu. Select "Last Known Configuration That Worked".
Toshiba Tecra M10 hanging when windows is shutting down after an update
Are you sure you are not too fast or impatient for it. Sometimes after doing updates it might take awhile to get past the Windows is shutting down...
Give it some time and see what happens. If after 15 minutes it is still there, press and hold the Power Button until it shuts off then Reboot. Try shutting down again and see if it hangs.
May 14, 2012 | Computers & Internet
My nikkon coolpix is a month new and almost only 3 weeks used..my uncle bought it in states...when i am taking pictures i zoom it and a message "LENS ERROR " appear on the screen and because i...
1.Check if something block it (maybe sand or smt like that
2. Never pushed lens manualy (you may broke it completly)
3.Just try to shake or slap it jently while open or close it.
Jun 07, 2011 | Nikon Coolpix S3000 Digital Camera
Inspiron 1525 crashed during stage 3 configuration
Follow the instructions here to repair the OS, then manually install the update that causes the issue before enabling automatic updates
http://news.softpedia.com/news/Get-Vista-Out-of-the-Infinite-Reboot-Loop-Configuring-Updates-Stage-3-of-3-0-with-Vista-SP1-78933.shtml
Apr 03, 2010 | Dell Inspiron 1525 Notebook
My inspiron 1525 crashed and I turned it off using power button. Every time it comes on again it says 'configuring update stage 3 of 3 - do not turn off your computer'. It keeps shutting itself off then...
1. Insert your Vista Media into your dirve and boot from it.
2. Select "Repair your Computer" from the list.
3. Select "Command Prompt" from the recovery choices.
4. At the command prompt change your directory to C:WindowsWinSxS
5. Type: del pending.xml
6. Exit and reboot
This will fix all Windows update reboot loops and does not require you to restore your PC to and earlier state.
Keeps coming up with configuring updates stage 3of 3 0% complete do not turn off your computer then it shuts down and comes back on again
Please use this solution thta I have placed on this forum.
Please follow exactly these steps then you computer should be working again.
I have used the following solution.
Restart computer.press f8 then choose option restore computer.
choose option open command.
type: prompt winsxs (press enter)
type: move C:\windows\winsxs\pending.xml text.xml (press enter)
type: exit and restart computer.
Computer should be working again.
good luck.
hope it works for you.
pieter.
Oct 17, 2009 | Dell Inspiron 1525 Notebook
Acer Aspire 5735Z - Vista Home Prem. shutdown hang
updates can be slow,and lead to more updates sometimes.you should goto windows update,let it search for important updates then install them.even if it takes a while,once you do that it should be fine.and configure updates to auto download but ask to install.
Sep 20, 2009 | Acer Aspire 5735-6694 Notebook
My new lenova thinkpad t400 seems to be caught in a loop. I've taken the battery out and ctrl alt delete but still goes back to configuring updates: stage 3 of 3 screen and then says shutting down, but it...
Hello!
This is a tough one. I've seen this recently and had to just press and hold the power button to shut down. Not good!
I'm assuming you're using Windows of some sort since it shows "Stage 3 of 3" when it does updates during shut down.
What has happened is you downloaded some sort of "fix" from Microsoft and it's getting stuck while trying to install. I've had this happen and have never found a good solution for it.
1. Turn you computer off.
2. Turn your computer on
3. As soon as the power comes on, start pressing F8 repeatedly.
4. When you get a black and white menu, use your arrow keys to move up and down, select "Last Known Good Configuration" and press enter.
What the solution I've provided does is revert your computers software to a point in the past, hopefully just before you received the screwy update.
Make sure to rate the solutions you get!
Aug 08, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
Configuring updates
If it is windows xp OS plz do the following these step.
start the pc in safe mode and select the administrator login then
go to start programme go to acssories select the system tool- selcet the restore option, turn on windows in previous back day and resloved the porblem,.
bye
Jul 30, 2008 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
