FAV6800A/FAV9800A Outer Tub bearing replacement
See what is involved and iff you decide to go forward I will help on that forum. This forum is just to difficult to work in with no edit feature.
The Clicking sound may be a broken Large Wrap spring.
Place the washer with a load in the wash basket start a Spin Only cycle and release the washer top jus high enough to observe wash basket Spin action. There may be none to very little. If you drop the Clutch Pulley out I believe you will find much rust. You have to replace that tub seal and I would do a complete outer tub rebuild. Without replacing the Clutch Pulley around $60 for bearings, Tub and Seal Tranny O-ring.
Review the post FAV6800A/FAV9800A Outer Tub bearing replacement and see if this is a direction for you.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800A top load machine.
Google this FAV6800A/FAV9800A Outer Tub bearing replacement to see what is involved in doing an Outer Tub Rebuild.
Good Luck
