FixYa.com
Tags:
IBM Infoprint 1116 Laser Printer
Error Light
posted by jkalin196511 on Jun 14, 2008
I just replaced the toner cartridge on my InfoPrint 1116. Even after changing the cartridge the error light stays on the toner low light continuously blinks. Any help will be greatly appreciated.
Sincerely,
Jim Kalin
Comment by jkalin196511, posted on Jun 15, 2008
Can you tell me where the contacts are, and what they look like?
Thanks,
Jim
I think I've got it figured out. It had something to do with a gray sponge like roller in the bottom of the printer. It must have came loose during shipping. I don't get the error anymore, but the print quality is not the best.
J
I got in back in place. I of the clips that hold it in place was out too. It prints much better but after every second or third page three small smudges show on the left hand side of the page. Other than that it seems to be working perfectly. Are the transfer roller expensive, and where can I get one?
Thanks,
Jim K.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
Bubbabear64
Rank:Wiz Wiz
Rating: 83%, 847 votes
Make sure you shake it up when you install it too. The toner and developer may not be evenly applied in the cartridge.
Comment by Bubbabear64, posted on Jun 15, 2008
Thats the transfer roller. That will give you copy quality problems if it isn't installed properly.
You might want to get a new one in case the roller is broken. It wont distribute the toner over the copy very well if there is something wrong with it.
There must have been a reason why it was out.
You could check with Lexmark. I think IBM transferred support of their printers over to them.
Sometimes the rollers need an electrical charge to work properly too. Usually it gets it from the shaft ends of the rollers. if you see and metal plates in that area you might want to make sure there getting contact there.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 14, 2008
Not Rated (0)
waynechurch
Rank:Wiz Wiz
Rating: 83%, 122 votes
The error is "toner cartridge error" you could try cleaning the contacts inside the printer (with the power off, of course). If that doesn't work you will need to try another cartridge.
Comment by waynechurch, posted on Jun 15, 2008
Your printer is the same as a Lexmark E322, if you google Tranfer roller for lexmark e322 ibm infoprint 1116 you'ii find several places that sell it. I would take a look at the image drum at the bottom of the toner cartridge and see if those marks are present on that, if so clean them off with a soft cloth, also check the fuser (the last unit the paper goes through before coming out of the printer, normally quite hot) if the marks are on that try cleaning them off with a cotton bud.
Can you Help with these Printers problems?
Printers
I want to print envelopes
I want to print envelopes in a... Answer This...
Printers
says i'm out of color
says i'm out of color ink. I... Answer This...
Printers
error message: print head not
error message: print head not... Answer This...
Printers
AFTER INSTALLING MY HP DESKJET
after installing my hp deskjet... Answer This...
Printers
PAPER FEED LIGHT IS ON
paper feed light is on Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
