Question about Coleman Powermate Powermate 5000W Generator
Is there a gas filter on coleman 5000? runs until hot then shuts off
    President:
  • Coleman Master
  • 1,400 Answers
There is somewhat of a filter inside the tank, however your issue could be air lock or faulty oil sensor. Try running the generator with gas cap loose to allow more air into the tank. If cap is fault try to clean cap vent ports with carb cleaner or just replace the cap. If not fuel lock, remove wire from oil sensor and test again.
Posted on Nov 05, 2010
Engine runs untill hot 5 min in after cooling down will restart and run another 5 min
sometimes as a spark plug or coil break down will give these symptoms. replace the spark plug. if this don't fix it my guess is when the coil gets hot if quits firing . replace coil. i've had to do this a few times. good luck
Mar 14, 2016 | Toro Used 60" Z Master Professional 5000...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Coleman power ate 5000 generator, will start very easy, run for 1-2 minutes then shut down, what could be the problem?
Check oil level, and viscosity is correct 30W etc
Then check oil presure switch and wiring
Aug 28, 2012 | Coleman Electrical Supplies
My powermate 5000 with subaru engine will run anywhere from 30-60 minutes and shut down. One light pull to the pull start and it runs great for another 30-60 minutes. Never a problem to start it back up...
There is debri or dirt in gas tank and eventually it gets sucked up and clogs the screen filter on the end of gas line. Drain gas tank and flush out a few times. let dry and put new gas in it. check your gas can, if it is metal, it may have rust in the bottom of it and it goes in the gas tank and clogs screen, make sure you have a clean gas can that you use to fill the generator.
Aug 25, 2011 | Coleman Powermate Subaru 5000W Portable...
Where do you buy the gas shut off valve for the 5000 power mate coleman generator with a 5 gal plastic tank.
Take the old valve, called a petcock, to a local lawn mower repair shop and they should be able to help you.
Jul 13, 2011 | Coleman Powermate Powermate 5000W...
Hello, I'm trying to get an old Coleman Maxa 5000 ER Plus to work again. The interesting problem is that i can get it to start and run, IF i squirt gasoline into the carb throat with a squirt sprayer, but...
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Dec 21, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
I tried to start my new coleman powermate 6250/5000,
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Apr 24, 2010 | Coleman Powermate Premium Plus 6250W...
I bought a used coleman powermate 5000 generator, I replaced the spark plug and fuel filter, it finally started up,it would only run in the "choke" position it ran about 10 minutes and then shut down, I...
What brand of engine & horsepower is it?Also about how long was it stored or last time it was run? The reason I ask is if it was stored with gas in it & a fuel stabilizer wasn't added to it,your primary jet is plugged in the carburetor(reason it will only run while choked).
Jan 07, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
255 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
