Obselete parts needed. Out.side plastic cover needed for Duo Therm Model 55715-041.AC unit. Any possible sources? Thanks.
  • jlwseat Nov 05, 2010
    It is a one piece molded plastic box (RV unit) style on a 1981 32 foot cabin boat.
    Top Expert:
  • Heating & Co... Master
  • 83,810 Answers
I have been unable to find any sources for the soft parts of this unit such as the front cover
Posted on Nov 04, 2010
  • Marvin
    Marvin Nov 05, 2010
    I have no resource's that have any parts for anything this old, sorry but this has been out of production for decades.
How do I stop my Domestic Duo Therm AC from leaking inside?
as all ac units produce water when operating, there will be a drain hole and tube to the outside of the unit
possibly under the cover or lining
it will be at one end of the drain pan and you may have to use a bit of wire to push out the gunk and dust that will be blocking the hose
other than that take it to a caravan shop and have the technicians clean out the hose for you
Jul 08, 2018 | Heating & Cooling
Where can I find the model number on this old Duo-Therm roof AC. Is it possible to recharge it?
Take the cover off to see the data plate. There may be one inside by taking the inside cover that holds the louvers and filter in place. If it needs to be recharged, then there is a leak in the metal tubing. That has to be located and repaired first. Install a drier on the low side to absorb any moisture let in by the leak before evacuating the system for freon.
Aug 07, 2015 | Heating & Cooling
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo Therm 1500 AC leaking water inside RV after about one hour of cooling. Condenser drain tray is draining OK
On your cold side air coming in, does the ductwork have any insulation on it? Also The evaporator (front part, up where your filter is ) may have a plugged drain tube, depending on year make & model. Not uncommon for some to have a cracked drain pan as well. Your best bet may be to pull plastic cover off unit, then look on side of evaporator housing & see if you notice a tube sticking out side for drainage. It may be plugged if there is one there, use a piece of coated wire or similar and try cleaning it ou, carefully, don't ram it in there and hit coils too hard.. You can remove the 5/16" head screws that hold cover over evaporator, and pull that cover forward & have a look as well.
Aug 12, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm AC/Heating not working at all after tripped breaker.
I had to get on the roof of mine, remove the cover and manually spin the fan. Add a little oil to the shaft where it goes thru the bearing. All of this is done on the roof side. Mine required this procedure every spring. Duotherm realizes they had a problem and have since corrected it but they don't deal with all of their customers that had the original problem.
Jul 20, 2009 | Heating & Cooling
Duo-Therm AC does not work
fan motor is possiblely bad but start with the capistors in the run box on the roof remove cover you will see where all the wires go onto a metal or plastic box depending on age of unit remove acess cover peek inside and see if you see a exploded capistor ie: i see smoke comming out of my ac capsitor are easy to change but they can kill you they store a lot of energy and are dangerous if you are not careful with them
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
DUO THERM 590 QUICK COOL AIR CONDITIONER PART NEEDED INTAKE GRILL
you could contact the manufacturer of the rv and they can help you with you search. Hope this helps
Dave
Jul 16, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
