Question about Amana 5939 Grill
I have an AM33LP 5 burner Grille. I have the same problem as previously reported. Each time I turn on, the flames get lower but not all the time. Sometimes works perfectly, I thought that the colder it was the more it happens. Burners are clean, LP tank is full. Could it be the Regulator?? Not losing LP, don't suspect a leak.
    Top Expert:
  • Amana Master
  • 53,373 Answers
When the temperature falls the orifice shrinks there by not letting as much gas thru and there is no remedy for it just have to cook longer is all .
Posted on Nov 21, 2017
4 Suggested Answers
SOURCE: 1st burner goes out when 2nd burner is turned on
I had the same problem. They original regulator and hose were poorly designed for this model. There isn't enough room underneath without crimping the hose. I bought a standard regulator and shorter hose combination a Home Depot for about $20. It makes a 90 degree turn coming out of the tank and does not kink the hose.
It was worth the $20.
Posted on Jun 03, 2009
  • 57 Answers
SOURCE: My Amana 4 burner has lower flame each time a burner is turned on
it may not getting enough gas to it for one thingbut it could be your air vents my be open to much. reajust them on the burners
Posted on Aug 23, 2009
  • 3351 Answers
SOURCE: I have a 5 burner
it could be the burner is block try blowing them out with air line or shop vac on blow or orffice could be blocked
Posted on Sep 16, 2011
My grill won't heat up. If I reset the regulator and turn a burner on I can light one burner and flame seems fine. When I turn a second burner on the flame goes down.
The pressure regulator has gone bad. It isn't expensive and can be bought at Walmart or other home improvement stores that sell outdoor grille parts.
Aug 16, 2017 | Grilling
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
When I turn the on the first burner will light and flame are OK, but lighting the next burner the flame goes down to a point that you can barely see the flame. It appears that the gas get reduce to have a...
sounds to me like your other burner isn't getting the same amount of gas flow. what you need to do is give your grille a good cleaning and check the lines for any leaks. you will always smell gas so it will be hard to tell by smell alone. Test your lines by wrapping them tight with foil or something removable and turn your grille on to see if the flame gets bigger.
Oct 04, 2010 | Grilling
Flare ups
turn one of the burners off and put your meet over that burner
May 25, 2010 | Kenmore BQ06W1B (LP)
Flare behind temperature knobs on jenn-air gas grill
This seems to be a problem for most Jenn-Air users. The burners are defective, rusted or clogged and allowing the flame to "back up." You most likely have a melted electronic ignitor as well as gas valve damage. The new burners that I received this week for my model 720-0061-LP are 1/2 inch shorter than previous versions. Time will tell if this fixed the problem. I would call Nexgrill and get all new burners and inspect the gas valve area for damage. Since 2004, I am on my 5th set of burners, glad they were free since I have a lifetime warranty on my model.
Apr 17, 2010 | Grilling
Aug 23, 2009 | Amana 5939 Grill
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Amana 5939 Grill Logo
173 people viewed this question
Top Amana Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you an Amana Grilling Expert? Answer questions, earn points and help others
