Order part #W10017820 (do this first before you open up the range). While you are waiting for the part to arrivedown load the parts list from kitchenaid.com. When you have the part, Shut offpower to the range. Then remove part 9762612Vent, Center (pull the oven door toward you, you will see four screws). Before you proceed, place a stool with booksor a **** of paper or what ever it takes to equal the height of the bottom ofthe control panel. Then remove part 4457249Face, Control Panel (two screws, right and left, under panel). DO NOT DROP PANEL. The panel is connected via wires so please be careful. Set the panel on the raised surface that youcreated. Replace part W10017820. Replace control panel. Replacecenter vent. Restore power to unit. RP appears in display. Set clock. You're good to go.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
