Replacement for capacitor 120mf/200v
Is there any replacement that i can use for this capacitor 120mf/200v?
hoping that you can help me regarding this problem....
    Genius:
  • Televison & ... Master
  • 1,689 Answers
You can use anything from 100 to 150 uF (mf, or mfd) in over 98% of the applications. Most of these caps have a 20% tollerance in their uF value. If this cap is being used as a power supply filter cap, or a bypass cap, the value will not be critical.
As long as the voltage is greater than the required amount it is acceptable. A poplular value would be 100 uF / 250 V. I rarely see 120 uF caps in equipment.
A higher voltage cap will be physicaly larger. This can become a space issue when installing the replacement.
With the new cap, make sure that the polarity is corrent when doing the installation.
Jerry G.
Posted on Jun 14, 2008
I have wine cooler the capacitor pop up ,but i do not know where i buy the part of 120UF,200V
Is this the round type capacitor? Do you see a part number on the capacitor?
Nov 13, 2012 | Haier BC112G Wine Cooler
Right edge fades to black (Approx 2")
ok! you have defective horizontal linearity check horizontal section then check capacitors! like 180uf 200v or 200uf 200v. the problem is defective capacitors!
Sep 28, 2007 | Toshiba 44NHM84 44" TV
Samsung 19 inch TV(Model no, CS-20F2Z),,,,,,,,,,,,,Screen going blank after some minutes.....Transistor d2499 shorting power. Replacing the transistor does not solve the problem since after some time it...
try to check the capacitor beside that transistor or replace that capacitor, i think that the value is 200v 10microfarad im not sure but you will see that capacitor,try to replace it.
Jul 07, 2011 | Samsung Televison & Video
Power light does not come on.
I had this problem with a Philips TB100HH9 and opened it up and it looks like a capacitor burned up because some white substance came out of it (82uF 200V). I ordered a replacement from Digikey and hopefully that will fix the issue.
Jun 24, 2011 | Philco TB100HH9
The picture is distorted with diagonal lines
on the back of the sets there are two knobs one over the other one saying screen and one saying focus perhaps or they may just be there if your standing behind the set they would be on the right hand side lower rear area
hello let me be simple...
If you see them try pushing input button on the remote so you have a blank screen and then turn the screen control slightly till the lines are gone
and then go back to normal signal
I hope this has helped. Regards Gizokieth
Sep 10, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Makita DC18RA charger conversion
You can't use the same capacity as it gives you a very
large and expansive capacitor.
I used the max. diameter of 30mm that could go into the PCB of the model I have and it is 470uF 400V
You'll need to replace another capacitor, see my mod page !
This works !
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
all the components details are in it
Have fun and good luck
Jan 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
470uF capacitors
The 470uF/25V Caps are in the middle of the PCB alongside of the slab-looking aluminum heatsink. You should be able to see that the tops are popped up and the glue around them is brown from overheating.
Jul 21, 2008 | Philips HTS3450 System
INTERMITTENT SUPPLY
hi there, a defective filter capacitor means a more defective parts near that part, do some test and check up with the rectifiers, resistors, and regulators. just consentrate on power supply section. ty
Mar 10, 2008 | Thomson 29DM400 29" TV
Screen went full bright one day.
Hello, please check the 10uf/200V capacitor around flyback transformer. Best regards, Arpi
Jul 17, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
443 people viewed this question
Top Televison & Video Experts
