Question about Maytag Neptune MDG5500AW Gas Dryer
Beeping in my Neptune Dryer
My neptune dryer is beeping when it isn't running. It sounds like the beep that happens when the dryer shuts off, and it isn't constant, and it doesn't happen all the time. any ideas?
  • 2 more comments
  • Beba1943 Jul 08, 2008
    My Maytag Neptune MDG5500AW Gas Dryer is doing the same thing and we had to unplug it to stop it.
  • Anonymous Jul 27, 2008
    Mine beeps when off and when running...
  • willowhawk Jul 28, 2008
    I have the same problem, I have replaced the motor and the control board. The dryer worked great, still would beep for no reason once in a while but it worked real well, Until today!!! I put in a load of wet clothes and closed the door the board lit up to sensor dry and the time but when I push start.... nothing!!! Any ideas????
  • tictic24 Dec 02, 2008
    constant beeping. repair man didn't know what to do, shrugged it off. Company told me to "call a repairman". I am at a loss.
  • 979 Answers
This is a mystery to me. Try typing into google "beeping sound on Neptune dryer". There may be a solution on there from Neptune or someone who has had a similar problem.
Posted on Jan 14, 2009
It is apparent that the beeping sound has something to do with the control panel (membrane) or the computer board behind the panel. We have found the source of the problem and can help. The problem often stems from water vapor working its way into the membran via the lack of a seal around the digital display. The membrane is supposed be sealed to avoid ambient atmosphere from entering the membrane and causing low resistance bridges between contact with the membrane. Many cases appear during humid weather which lead us to investigate the possibility of water vapor entering the membrane. In all control panels the seal around the digital display was non existent.
With a little skill the computer board can be tested before you invest in one. You can disconnect the cable leading to the membrane and use a paper clip to jumper the contacts and see if the computer board responds with a beep each time you jumper one. There is a schematic in the control panel that show which contacts close which switches. So if you know a certain button is not working you can jumper those contacts and see if the computer board responds. As always, be aware that there are electrical dangers on the board but the membrane plug is not dangerous to test. For the techs in the world, the water vapor probably leaves conductive deposit that cause high resistance leaks between contacts which will close several switches at one time causing the stuck switch error or beeping. A hair dryer might help dry it out but I believe the deposits will remain. WD 40 might work if you can spray it around the digital display and the ribbon cable connection point. If the dryer is subjected to lower than room temperatures condensation within the membrane will be more likely. The cold air coming in, through the vent, will lower the temperature and cause condensation as well.
Testing the computer board can save time and money. The input to the computer is easy to test. We have yet to see a computer board that had major problems.
**** Leidich
Leidich Technical.
Posted on Sep 27, 2011
Electric went out.now it is beeping,how do I fix it?
unplug it for awhile. Then google " Maytag Neptune MDE5500AY causes for beeping" . Click on appropriate link, and follow what it says
Apr 09, 2015 | Maytag Neptune MDE5500AY Electric Dryer
Making a beeping sound and will not startr
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer bips Problem with the Maytag Neptune MDE5500AZW, SER N 73252332JX Electric Dryer. It bips all the time. Some times don't want to start. Please let me know what is the problem. Thanks! Reema...
Mine does the same thing (it's doing it right now!). I had it looked at and they said I have to replace the mother board. It's going to cost me $300! It stops beeping and works normally most of the time. When the house is humid, it starts beeping again.
Maytag is total garbage. Our Maytag fridge had to have a new compressor installed after only a few years. Our washer and dryer are only a few years old as well. Never buying Maytag again.
Jan 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
We own a Maytag Neptune Dryer Model No. MDG5500AWW and have already replaced the mother board. The dryer began beeping periodically and then it just won't start - controls are frozen but they do light up....
If you hear random beeping and a double beep sound when you are pressing a key it means that your problem is the keypad itself, not the board. The keypad on this model is the entire console (not a cheap part @ $200 but this was a very well built dryer so probably worth the repair). You most likely have one of the keys that is shorted out on the console that is causing all of your troubles.
Get yourself a new key-panel part number 33002536 and replace it and you should have your problems solved.
Good luck and please let me know if you have any other questions on this!!
Aug 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune dryer beeps a lot and does not run.
what is the model number,sounds like you have a bad computer board but the problem is alot of parts for the neptune are no longer available
Sep 16, 2017 | Maytag Dryers
Neptune Dryer Just Stopped
The user manual can be found here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/2206682B_MD55.PDF
The service manual can be found here: http://www.servicematters.com/maytag_library/docs/16023110.pdf
It does sound like the belt.  Refer to the service manual above on installing a new belt or troubleshooting for other issues.
Apr 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Beep beep beep
Temporary Fix: unplug the dryer or cut its power at the circuit breaker panel, when not in use. If the dryer alerts/alarms are set to silent and the beeping happens when it's not in use, chances are it's the same beeping you hear when you first introduce power to the unit or press start. This may indicate a short affecting the control board. If you need to press start multiple times to get the dryer started, then the control board components are most likely starting to fail.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
May 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune gas dryer beeps.
NO RESETS OTHER THAN TO UNPLUG THE DRYER FOR 5 MINUTES, THEN RECONNECT POWER. ON ANY ELECTRONIC CONTROL, THIS WILL RESET THE CONTROL'S MICROCOMPUTER. IF THAT DOESN'T SOLVE THE PROBLEM, THE TOUCH SWITCH MAY BE FAULTY.
Apr 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
1,046 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
