Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Washer won't drain water
How did you get to the bottom of the washer - did you tilt it back with the water in it or did you tilt it onto the door
  • 1 more comment
  • frigidale Jun 18, 2008
    Washer won't drain water problem. Washer started and cycled only first part but no rinse and water still in washer.
  • tensecondtom Jul 11, 2008
    I have a Frigidaire front loader -5 speed heavy duty.
    ISSUE #1 -Not too long ago, we started noticing an odor coming from the laundry room whenever we put a load of wash in after a few days (maybe sitting water somewhere???).
    ISSUE #2- Now the washer makes a loud buzzing noise during the rinse cycle (like an-end-of-a-basketball-game buzzer) and does not drain the water from the washer. Clothes soaking wet, water still in washer.
    My most sincere gratitude to any assistance on this. Thanks.
  • Anonymous Jul 18, 2008
    Mine ATF6000 is only 1 month old and is having the problem that you guys have ..... I guess I have to call service tech tomorrow ...... I the other post franco66 mentioned that he has to have the pump replaced .... Now I have to have my fingers cross ....
My will start to cycle and then it will cease to spin. No grinding, no off balance noise-no spinning=no draining of water from tub/basin. Unplugged it for a full 4 minutes. Plugged it back in. Checked to see if washer was level-it wasn't. Made adjustments to ensure washer was level-EUREKA! washer finished cycle no problem. BOO-HISS! Two loads later, same issue as the first time-washer won't spin. Checked to see if washer was still level-it is, new issue-error coed E20 and all lights blinking. ANY suggestions?
Posted on Jun 18, 2008
Frigidaire washer model LAFW70000LWO leaking from bottom of washer
would suggest cleaning out the coin or filter trap to see if debris has clogged the drain lines. This may or may not be specifically for your model, however these are generics instructions that I found.
To check for a restriction in the drain line you will need to follow the steps below:
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
If any proves to be ineffective contact a professional so they can properly and accurately diagnose the unit for repairs. Unit could possibly have a damaged/cracked tub, a leak in the drain lines, or the water valve.
Dec 05, 2012 | Frigidaire Washing Machines
Frigidaire washer leaking from underneath
Hello greschina - You would need to clean out the coin or filter trap to see if debris has clogged the drain lines.
2. Pull the washer out to tilt it back so you can reach the screws below the front panel and remove it. (You will need something to catch the water once the hose is removed from the bottom of washer).
3. Loosen the bolt with the sliver clamp on the bottom of the washer. The water will begin to come out while your loosening the clamp. (Do not remove any GREEN clamps).
4. Once the water is out, you can stick your hand inside the hose to clean it out.
Oct 08, 2012 | Frigidaire FAFW4011LW Washer
My washer wont drain even if the pupm is running is it cloged
See if anything is blocking the drain lines and pump.
Sep 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
It doesnt drain
Sep 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
Aft6000fs wont drain
Aug 28, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire atf6000es drain pump access
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
How do I access the drain pump on a Frigidaire Affinity front loading washer?
If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Mar 01, 2011 | Frigidaire Affinity ATF7000E Front Load...
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Washer fills up fine but doesn't start to wash...
if it doesn't agitate, spin, or even drain, then you most likely have a belt that is off. Of course, now that you have a washer full of water, it is going to be diffficult to tilt back and change the belt, so you might want to get a shop vac and **** the water out through the drain hose first.
With most of the water out, you should be able to tilt the machine back and see what went wrong. I believe on Frigidares the belt is underneath.
Mar 08, 2009 | Frigidaire GLWS1233A Top Load Washer
Washer will not empty water, wife washed backing came off
in the pump its at the bottom of the machine and where the drain hose hooks up. youll have to tilt the machine to get to it
Feb 25, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
2,179 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
