Question about Microwave Ovens
Need to know how to set a delay setting to start my oven while iam at work. my stove is a viking about 1980ish it has touch buttons and dials that i would have to set I think. the dials are for the oven contro and tempature control
  • 3 more comments
  • lindakobza Nov 04, 2010
    this is not a microwave oven it is an oven with a stove top. a regular stove
    this is not a microwave a regular stove oven
  • lindakobza Nov 06, 2010
    my stove model # is eatons viking ss 309 ow-4 NF 035 07023 9( this is not a micrwave oven)
  • lindakobza Nov 08, 2010
    please put me in contact with Viking Stoves serial #ss3090w-4 NF03507023 need to know how to set oven to come on at a delayed setting time
  • lindakobza Nov 09, 2010
    my stove serial # is ss309ow-4 NF03507023 I need instructions on how to set oven dials and touch buttons to use a start delay for my oven of the viking stove
    Genius:
  • 1,035 Answers
Hi. I provided you a link for you issue. Hope this helps.
Posted on Nov 08, 2010
  • 757 Answers
Do you have a model number of the unit?
Posted on Nov 04, 2010
    Brigadier General:
  • 5,158 Answers
Set the microwave to the settings you want to cook your food and purchase a wall timer that you can plug the microwave into and set the time on the timer to turn on the microwave at that time.
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
How can I fix or bay the one touch door open button?
This service manual shows the parts breakdown and the part numbers: Viking DMOC205SS Service Manual
Jun 18, 2014 | Viking DMOC205SS Microwave Oven
Hello. I just received a new Glass Touch ASM (WB27T10875) for my GE stove. My previous one cracked and needed to be replaced. Problem: While installing/ connecting the ASM to the stove, once I connect the...
Funniest thing. I was having the very same problem on Monday. Every time I laid the glass touch panel down on the stove, it stopped working but worked when I held it up. After failing to install the panel so it would work for 30 minutes, I walked away from it and ate dinner. Coming back later, I decided my problem was the connections on the back side were coming into contact with the metal so I placed a tightening knob in the center of each of the outside holes making sure the underside of the knob went exactly into the middle of the hole. I then lowered the left side of the panel down to where the threads started and very carefully partially tightened the left knob so none of the panel back touched the stove. I then lowered the right side until the knob touched the knob and tightened that side finger tight. I keep testing the buttons to make sure they were still working. When the out side knobs were finger tight, I finger tightened the 2 inside knobs. Success. My oven is now working.
Aug 03, 2013 | GE GLASS TOUCH ASM WH - WB27T10873
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have an oven which I believe is a Kenmore model # 911.93251590 that the printed temperature numbers have worn off around the dials. I was hoping to find a picture of the stove or a manual assuming it...
Get an oven temperature gauge and place it in the oven, turn on the oven with the dial set at a near mid position letting oven stabilize in temperature. Read the temperature and mark the dial. Repeat at select positions marking the dial with the new temp setting.
Jan 27, 2018 | Microwave Ovens
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
THE START BUTTON WILL NOT START THE OVEN, WE HAVE GE-JVM1790
the start button uses carbon pads and they could be worn out or not contacting properly you try and replace the control pads
Jul 26, 2010 | GE JVM1790 1000 Watts Convection /...
Will not start
I have the same problem, diagnosed as bad touch screen panel.
Apr 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Setting clock on EM-G2567S
1. If you press the 'Delay Start' button, the time display will go blank.
2. Now enter the correct time, using the 'Minutes' buttons to set the hour, and the 'Seconds' buttons to set the minute.
3. Now press 'Clock'
4. Sorted!
Nov 25, 2009 | Sanyo Microwave Ovens
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
