Question about Nikon Coolpix 5200 Digital Camera
The door for the battery will not stay closed.
    Guru:
  • 2,178 Answers
A spring is not releasing the lock. Inspect the door for the spring and try to loosen it.
Posted on Nov 04, 2010
94 jeep something is draining my battery will key light on ignition drain my battery,,it stays on when not running, ?
So if your courtesy lamps are staying on after the vehicle is off, and all doors are closed, after 15 seconds, than i would look into your doors and see if one is not fully closing. Each door including the rear hatch have this little black button behind the body latch component. When the doors are fully shut the lights turn off after around 15 seconds, but if one door is not closed fully, than the lights do not shut off because the car does not know the door is fully shut
Nov 16, 2018 | Jeep Cars & Trucks
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
I can't keep the battery door cover closed on my Nikon coolpix digital camera L.22
I see this message at least 3 times, so it must be important.
Looks like a mechanical problem. But not having the camera in my own hands I have to do some educated guesses.
Could be something broke off. Could be a small chip of plastic or a very small piece of metal. Difficult to repair it yourself. But you also could look if there is something in the battery compartment that should not be there. Could be just a little bit of debris, that is lifting the battery, (not if the battery is behind the lock) or debris in the door, so you can't close the battery compartment complete, and it can't be locked.
If you can't find anything and it looks as if the battery compartment closes correct, and still you only can't lock the door, please visit your dealer or the Nikon service centre closest to you.
Nov 19, 2013 | Nikon COOLPIX Cameras
Battery door dosen't stay closed
After you close the door hold it closed then slide it forward
Nov 19, 2013 | Nikon Coolpix L22 L-22 Black Digital...
My battery door cover doesn't stay closedbattery door
Push it closed with thumb .. hold closed..then slide forward
Door open indicator stays on, drains battery
well thats easy , huh?
but the switch is closed , door closed.
so just short the door switch wire.
now you will exit veh, with keys in car, and sad days ,get worse.
same with head lamps left one. oops, no more warning.
Jan 23, 2013 | 1993 Geo Metro
The screen for the DVD player in our 2006 up lander will not turn off. It is draining our battery how can we disconnect so the screen can turn off
mine does the same thing, theres a switch inside the drivers door that is going bad..turn the key off slowly with the drivers door closed.then open the door and get out, close the door, .if the radio stays on go to he passanger door open and close it, if that does not work you have to discontect the battery under the hood each time you get it..the van is junk, sell it as soon as you can!
Jun 27, 2012 | 2006 Chevrolet Uplander
I dropped my Fujifilm s1000fd and the battery door wouldn't stay closed, so I had to tape it down for it to work, now it won't turn on at all, how can I fix it?
It is possible that because you had trouble with the battery door not staying closed the intermittent power from the batteries has blown the fuse inside. Thats just a guess tho but my S1000fd also has a damaged door catch and I drilled a hole through the battery door and glued a nut where the catch used to be on the top of the battery compartment and fastened the door with a screw. Job done.
To fix your power problem would involve finding the fuse, or what ever has failed. Search online for a repair manual - shouldn't cost too much
Nov 23, 2009 | Fuji FinePix S1000FD Digital Camera
Nikon Coolpix 5200 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
