On my Panasonic Pv-v4022 , If I record anything and play back or just play any tape, my picture is very snowy. I tried the Panasonic wet head cleaner cassette and I took off the cover and cleaned the video head with alcohol (which got a lot of dirt off and the guides) and it got a little better but is still bad. Any ideas?
If there is snow from the VCR only when the tape is being played, it is possible that there is a head clog or dirt on the heads.
If the head is clean and there is still snow from it, this means that most likely it is faulty.
A service tech who is experienced at servicing VCR's can connect a scope to the pre-amp test points, and run his calibration tape. With this he should be able to look at the signal carrier envelops on the scope and see if there are any faults.
At the same time, he will also see if there is a fault with the head pre-amp area. I've rarely seen any faults in the pre-amp area.
An experienced tech who works on VCR's can change the head for you. This is time consuming because he will have to go through all the guide and tracking alignments with the scope and test tapes.
A problem with most VCR models, unless it is a high end industrial model, most manufactures are no longer supplying replacement parts. They are telling the people to buy a new machine.
In reality, it may not be cost effective to service your VCR. You may end up buying a new one.
VCR Lock Activated message appears when I hit Play. Why and how do I get rid of it so I can play a...
(More)
VCR Lock Activated message appears when I hit Play. Why and how do I get rid of it so I can play a tape?
How to retrieve tape so it will play in another machine? Can NOT turn on. Unit lites up BUT only...
(More)
How to retrieve tape so it will play in another machine? Can NOT turn on. Unit lites up BUT only stays on for a few seconds then turns OFF. Tape inside machine still pulled out of cassette & thru spindles inside unit.
panosonic. The tv is a RCA I tried using a universal remote but it wont accept it .If i could...
(More)
panosonic. The tv is a RCA I tried using a universal remote but it wont accept it .If i could somehow put the time on this VCR it might work
i have dish network universal remote control and i would like to program it with my vcr panasonic...
(More)
i have dish network universal remote control and i would like to program it with my vcr panasonic pv-v4522. so what is the programing code and how do i program it?
