Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
White vertical lines in Zenith lcd projection tv
When my set gets warmed up in about 30 minutes, white vertical lines show up every 6 inches. Any suggestions?
    Novelist:
    Champion:
  • 203 Answers
Get price of a LCD drive board first, then call a shop to see how much they would charge to replace it. If you have already researched the price you can get a better deal. But I really wouldn't try to replace this yourself. It takes major disassembly and alot of training just to get this model taken apart and put back together. Good luck, Russmann.
Posted on Jul 01, 2008
Samsung UN55B7100WF has white haze on screen
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 30, 2016 | Samsung Televison & Video
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
32 INCH ZENITH PICTURE IN PICTURE ABOUT 15 YEARS OLD.PICTURE DISAPPEARED AND ONLY HAVE A THIN WHITE LINE RUNNING ACROSS THE SCREEN.THE SOUND STILL WORKS FINE. IS IT WORTHWHILE GETTING IT REPAIRED ??
When CRT TV's show only a white/bright line horizonatlly It is a failure of the flyback Transformer. Not all that costly to repair. Your old TV will probably still be working when all the latest plasmas and rear projections have been laid to rest. Fancy junk TV's dont get any better programs than those old reliable ones
Please rate my help++++Thanks for using FRIXYA
Aug 04, 2010 | Televison & Video
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
26PF332026 inch phillips lcd
Go to this link :
http://teleservice.xooit.fr/t46-MODIFICATION-DALLE-LCD-QD26-EQUIPER-CHEZ-PHILIPS-ET-THOMSON.htm
Sorry, it's in French, but there are pictures of the modification to do.
Oct 27, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
