Question about Hobart D300 Stand Mixer
Transmission Grease for A120 and D300
What type of grease do these machines use for the transmission? What weight?
  • 2 more comments
  • dirtrider100 Aug 11, 2008
    I was wanting to know what type and how much grease is supposed to be in the gearcase on a D300 mixer ?
  • Daniel McAmoil Nov 26, 2008
    Just got a D300 mixer,, and its well used.. Runs like a watch but know it needs cleaned up and the oil changed..
    HELP!
  • Daniel McAmoil Dec 18, 2013
    The grease that was in it,, looked to me to be worn out 120w gear oil,,, I flushed out the gear case and
    and replaced it with a high dollar 75w/90 sync gear oil,, I over filed it a little and it would drip out a drop or 2 every few days, Now that the level is proper its stopped leaking.
    Problem Solver:
  • 6 Answers
Thanks,, great info..
I took mine all apart and the oil was just at the point of turning into grease. Nasty,, brown smelling ****.... I cleaned it all up and just used a sync 50w gear oil.. I over filled it and the extra ran out of the motor end of the gear box... It might have been about 2 table spoons too much.. Now it does not leak anymore.
Thanks again,, jaybeesee
Daniel from Penokee
Posted on Mar 10, 2009
MobilGrease XHP 220 Hobart Part Number 00-103881-00044. My D 300 T takes 40 ounces (or two cans) to repack the gears. The Planetary lubricant is 00-102973-00013 Exxon Spartan EP 150 Industrial Gear Lubricant. It comes in a 6-8 oz squirt bottle but you only need two ounces to fill the palnetary cup.
Hobart n -50 where do i put grease in, machine makes a grinding noise
If your N-50 is making a grinding noise there is a strong (almost certain) possibility that the cause is more than just needing more grease.
The sources of the noise are from the transmission case (front portion of the motor housing) and/or the planetary (where the blade attaches).
A search online should turn up the N-50 Service Manual.
With luck, it may be that the two adjustments specified in the Service Manual will do the trick
Three things come to mind regarding the noise:
1) If simply greasing the planetary does not do the trick, then
2) There are two adjustments to the transmission detailed in the Service Manual. And if that is not the cure
3) The transmission housing will need to be removed to find the source of the grinding. This is where the grease is truly encountered.
Sep 04, 2017 | Hobart Food Mixers
Hobart meat grinder,model 4322 asking what type of oil in gearbox to use?
You can buy food grade grease from kitchenaid or on amazon. I did use the grease from my work. Any grease would do the job just make sure you read the specifications to find the grease that can stand high heat so it doesn't melt while the machine is running.
Dec 13, 2011 | Food Mixers
Hello, my Hobart AE200 seeps oil from the front panel. How do I top it up? How often does the oil need replacing and with what type of oil? Thanks
It's not oil in the A200, it's #2 weight grease. Although when it gets old enough it can break down far enough to basically become oil (either that or someone put oil in it previously). There are a number of answers written on fixya.com explaining how to disassemble the transmission and change the grease. Fill with 36 ounces #2 grease. FYI : disassembling the transmission and changing the grease is a very messy task and one can VERY easily reassemble the transmission incorrectly, so consider bringing the mixer to Hobart to have the job done.
Aug 17, 2011 | Hobart A200 Stand Mixer
What kind of oil i can used for hobart d300
Transmission uses #0 weight grease, best to get direct from Hobart (their grease is the correct weight and approved by U.S. FDA & USDA as safe for use in food equipment) but if you insist on not doing so, at least obtain an Extreme Pressure #0 grease and don't overpack the transmission, I believe it should have 35 oz. if memory serves right.
Uses a heavier grease for the planetary gear, use #2 weight. Don't need much, just a light coat on the planetary gear.
Bowl lift rails use medium weight oil, again use food grade oil supplied by Hobart.
Aug 02, 2010 | Hobart D300 Stand Mixer
I want to know about changing the transmission fluid, what type, how much does it take, where is the drain, how do you fill it and how often should it be changed?
Here is where you can buy the grease
http://www.food-equipment.com/Hobart%20gear%20case%20grease.htm
There is no drain cause it's grease that is used. It needs to be removed manually and the 3 shafts need to be pulled to get all the grease out. If you are not mechaniclly minded best taking to a professional.
Feb 28, 2010 | Hobart A200 Stand Mixer
Kitchenaide mixer...leaking oil underside of
KitchenAid uses a grease in the transmission, and anything that may drip from the transmission will be very low in quantity.
If you want to disassemble, clean, and re-grease to remove the liquid part that has weeped out of the existing grease, do so with a food safe grease.
Dec 21, 2009 | KitchenAid Food Mixers
Mixer was shipped on it's side, and arrived leaking oil, is it o.k. to operate?
Yes your machine is safe to use as long as to much was not lost. the manufacturer (whirlpool) always puts more grease inside the transmission than needed. As long as you aren't getting continuous leaking this will be fine to operate. you can buy more grease if a lot was in fact lost. this can be bought at an auto supply shop. it is a thicker bearing grease.hope this helps
Thanks
Oct 08, 2009 | KitchenAid Food Mixers
Does this machine ever need grease or oil?
No! Typically these are permanently lubricated at the factory.
Unless an expert that does repair work on this type of machine comes in and says something different. I would avoid opening this machine up and adding any kind of grease or oil. It may wind up in your next cake! :)
Oct 03, 2009 | KitchenAid K45SS Classic Stand Mixer
A200 Mixer/Medalist L120 Mixer by Hobart
Where is it leaking grease from?Im a hobart tech and service these mixers.When i go into work i will get you the part # for the grease.You would then have to contact your local hobart branch,tell them the part # and pick up the grease.
Feb 25, 2008 | Hobart A200 Stand Mixer
How do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Dec 23, 2007 | Kenwood KM400 / KM410 Chef Classic Stand...
Hobart D300 Stand Mixer Logo
1,063 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
