Question about TORK 711A 24 Hr InWall Electromechanical Timer 24 OnOff Cycles 15A
I need an electro-mechanical timer for decorator plate. Intermatic E1343 is no longer available.
Http://www.lutron.com/Products/StandAloneControls/Timers/MaestroTimer/Pages/Overview.aspx
Lutron makes a decorator plate countdown timer
http://waterheatertimer.org/Programmable.html
This page shows electro-mechanical dial-type timers, and it shows digital programmable timers.
The electro-menchanical dial-type do not use a Deco plate.
Instead each timer has it's own plate.
Now Paragon makes a multi-gang timer
http://waterheatertimer.org/images/Paragon-wall-box-300.jpg
http://midlightelectric.com/firex/acatalog/FIREXPARAGONROBERTSHAW_WB103.html
If you need more assistance, add a comment
Posted on Nov 05, 2010
Dear Sirs, I try to change Intermatic E1343 solid state timer to normal 2 ways switch. I saw the cable in 3 colors : black, red and blue. do ou know the menaing of each cables? if you can email me...
I think you mean Ei343 instead of E1343.
I have manual for EJ341 and EJ343 that shows wiring for single-pole and 3-way.
I believe the EJ343 is wired same as Ei343 since Intermatic Load rating chart groups these timers together.
http://waterheatertimer.org/pdf/Intermatic-EJ343-timer.pdf
Load-rating chart:
http://waterheatertimer.org/pdf/Load-ratings-for-Intermatic.pdf
Load chart implies this is 120Volt in-wall timer for inductive and tungsten loads up to 400Watts.
Now here's something to remember.
When any timer is wired for 3-way, the timer replaces one of the 3-way switches.
The other 3-way switch remains, but the other 3-way switch has to be rewired differently so that 3-way timer works correctly.
When removing timer from 3-way circuit, don't forget to re-wire the remaining 3-way switch so it works correctly.
To convert your timer to operate single-pole: Timer Black wire connects to Hot wire from circuit breaker. Timer Blue wire connects to wire going to Light. Red wire is capped off.
To see similar wiring illustrations for newer generation Intermatic timer, open following link:
http://waterheatertimer.org/ST01C-program.html#ST01C
Aug 01, 2011 | Garden
I noticed the Tork 1104 timer box was not working. It does not make a sound. And the clock does not move. I measured the incoming and outgoing wires with a multimeter and both measure at 240V. I'm...
13 years is good run for clock motor. Timer will last longer than clock motor.
Open following link to identify timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Tork 1104 has 240Volt clock motor
Frontier lighting sells the >> 120V Tork motor: List price 40.33/ your price 45.49
So 120Volt replacement motor costs as much as new replacement timer
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Intermatic replacement is240 volt T104 timer for $49.62 with 'free' shipping:
Also Intermatic trippers and clock motors are cheap and easily available
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88
Crossover wiring from 1104 to T104.
Tork L goes to Intermatic 1
Tork 1 goes to Intermatic 3
Tork x goes to Intermatic 2
Tork 2 goes to Intermatic 4
Intermatic A is not used unless you have neutral wire or 277V
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
GE sells the same 240Volt Tork timer under GE model 15307 in indoor-outdoor enclosure available at Home Depot for $59.00. Year 2011, GE does not pay US income tax, but takes US profits and pays tax in foreign nations. No replacement clock motor is available, but crossover wiring is same.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 09, 2011 | TORK Variable Cycling Timer 8601
How do you set this timer
You posted under T-106 timer.
This is electro-mechanical 208V 240V 277V 24-hour timer with NO NC load terminals
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t106r%20-%20english.ashx
Dial with current time has to be reset after power outage.
The silver pointer is positioned stationary at 6:00 position.
Lift and rotate dial until current time lines up with silver pointer.
For further information about wiring, add a comment with specific question and details about voltage, breaker size, wire size, and what Load you want to operate.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 14, 2011 | RTO Intermatic T106M Timer Mechanism Only...
I have intermatic timer T30003R. How do I change the timer motor
My understanding is this timer uses typical T100 series 120Volt clock motor.
The motor has identifying numbers printed on it.
T100 series 120V clock motor is available at Grainger:
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Selection of Intermatic clock motors are available on-line:
http://www.electricsupplyonline.com/prod/intermatic-motors.php
To replace motor:
Timer mechanism snaps out of box using a thumb-spring located at top of mechanism.
Clock is located on back of mechanism, and is held by 2 star-screws.
You can buy star screwdriver bit at auto parts store or hardware.
Clock motor has two white wires that are connected to terminals on front of timer.
Be sure to tighten terminals screws very tight after replacing clock motor.
Jan 10, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I need a replacement mechanism for a Paragon 24 Hr timer control Model 4004-71M.
1) Paragon is no longer making timers and parts except defrost timers.
4004-71M is not defrost timer.
2) Manual shows 4004-71M is DPST 40 amp 240Volt timer.
4000 series is 24 hour repeat timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
3) To buy replacement timer, Intermatic crossover guide shows T104M used for pool and spa controls and to replace timer mechanism
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
T104M at amazon
http://www.amazon.com/Intermatic-T104M-Mechanical-Mechanism-208-277/dp/B001DNYMV6
4) Or you can buy T104 with Nema1 indoor box, or T104R with Nema3R outdoor box
Googel search model number for vendor
5) How to wire T-104
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
Jan 07, 2011 | Paragon Vintage 24 Hour Timer Command 12...
I need trippers for an older model Paragon water heater timer Model TC-2. Can you help?
I don't recognize Paragon TC-2.
Intermatic cross reference does not have that model number either.
Paragon sent e-mail last month saying they were no longer making timers and parts, except for defrost timers. Your water heater timer is not defrost timer.
Here is a wide selection of water heater timers, electro-mechanical and digital:
http://waterheatertimer.org/Boxtype.html
Manuals and wiring diagrams are shown for most products on page.
I recommend simple 240Volt Intermatic WH-40 for price and reliability. Drawback is minimum 1 hour on-off.
Or Intermatic T-101 for 120Volt heater or T-104 for 240Volt heaters sold at Lowes.
Intermatic trippers and motors are available and interchangeable, and are made of steel.
Some new timers are made with plastic parts:
GE 15207 is universal 120V 240V and sold at Home Depot.
Tork has new universal electro-mechanical timer, TU-40 for 120 and 240 applications
I use GE 15070 in-wall timer from Home Depot for my water heater because I change times frequently and try to shave every dollar:
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
Add a comment if you need more help.
You can also take advantage of fixya phone support.
Fixya expert will walk you through any problem for a price.
Dec 22, 2010 | Paragon Hardware & Accessories
I need the instruction manual for Model # R8806R101C.
Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
R8806R101C manual is not shown on Intermatic, even among discontinued models.
But product is still for sale.
R8806P manual is available:
I suspect manual is very similar since it's a mechanical time piece. If not, then add a comment with specifics and I will help.
120V:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8815p101c%20-%20english.ashx
240V
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
R88 series sprinkler timers: click model number to see manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Nov 22, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How do I reset the time needle on my intermatic modle t101 The screw was loose and the needle move so
T101 Intermatic is 120Volt electro-mechanical timer
Silver pointer is located at 6:00 position.
Tighten the center screw with star screwdriver
Lift and rotate yellow dial until current time lines up with silver pointer.
How electro-mechanical timers work:
Place ON-OFF trippers on dial.
Trippers rotate around with passing time.
Trippers encounter on-off lever.
OFF tripper clicks lever one direction.
ON tripper clicks lever other direction.
Manual override lever clicks back and forth each time on-off lever is clicked.
How to wire T101:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Nov 16, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
How do i set the timer
You posted under Intermatic electro-mechanical timers.
If you have a different timer, add a comment with model number.
I have extensive files on timers.
To set Electro-mechanical timers:
Lift yellow dial and rotate until current timer lines up with silver pointer.
Notice that dial has on-off trippers.
Attach trippers to dial at times that you want timer to turn on-and-off.
Nov 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
TORK 711A  24 Hr InWall Electromechanical Timer  24 OnOff Cycles  15A Logo
61 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
