Won't agitate I have a Kenmore 80 series washer for 1998 and it won't agitate. i thought it was the timer box and i replaced it but didn't fix the problem. It fills, but when it needs to agitate it makes a humming noise and the timer box starts to smell bad.
  • 1,314 Answers
First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain, and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps. Then facing the washer locates the two screws. They will either be in the front or rear of the control panel or back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when you’re done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. Take them and clamp the hose coming from the tub but it’s not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
follow this but before getting to the motor coulping check to see if some thing is jamming the drain pump
Posted on Jun 13, 2008
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671..
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Washer only agitates and fills with water at same time.
The contacts in the timer are shorted (fused together). You can try removing the timer, opening it up and releasing the contacts that are fused together with a small flat blade screwdriver (look for burnt contacts). It might work for a while but it likely won't last. Your best bet is to replace the timer.
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
It won't agitate
after it fills do you hear any sound and does it go to spin on its own or do you turn the timer your self it could be a bad pressure switch thats what we are trying to determine
Feb 12, 2008 | Kenmore 24642 Top Load Washer
80 Series Kenmoore will not spin or timer move
the timmer were the knob is attached to has gon bad it very easy to replace 8 screws and one plug part can cost from 40-80 dolllars
Dec 19, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
