Question about Datamax DMX-I-4208 Label Printer
I print bar code labels constantly and as of late the bar code is not scanning. I have examined the label and it looks like there are some blank spaces in the label and it has gotten lighter. Any suggestions? Also the text is not what it use to be and have only had it 2 years.
    Scholar:
    New Friend:
  • 52 Answers
Sounds like your printhead is scratched, therefore needs to be replaced.
Posted on Apr 29, 2014
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Posted on Feb 12, 2008
  • 6 Answers
SOURCE: Zebra label alignment
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
EPL2 programming guide:
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/epl2_manual__en_.DownloadFile.File.tmp/14245L-001rA_EPL_PG.pdf?dvar1=Manual&dvar2=EPL2%20Programmers%20Manual%20(en)&dvar3=2746e
Posted on Apr 28, 2009
bartech9
  • 155 Answers
SOURCE: HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Posted on Jun 10, 2009
micromatikal
  • 2777 Answers
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Posted on Jun 25, 2009
  • 8 Answers
SOURCE: Brady ID Pal. Display says:
Brady printers have a sensor that reads information from the cartridge. The printer will not work if a connection cannot be made to the cartridge.The most common cause of failure is in the cartridge and switching to a different cartridge usually fixes that problem. Having the same problem with two cartridges is starting to indicate there is a failure in the printer, although it is possible (but not likely) to have two cartridges in row fail. A good first step is to be sure the printer is clean. If that doesn't work you'll most likely need to send your printer in for repair. A good source of free tech. support for the Brady ID Pal is Graphic Products. They even help people who are not their customers, They also do Brady printer cleaning and some repairs. They have an online for for requesting tech. support located at: http://www.graphicproducts.com/request-support.php or you can call 1-888-326-9244.
Posted on May 25, 2010
Printer not Printing barcode label properly
best guess would be a thermal printhead has an element out and needs adjustment. However with out a model number and a picture of the printout that is the best I can do.
Aug 24, 2015 | Office Equipment & Supplies
What causes intermittent skipping of labels? In the middle of a print job the printer will spew a blank label then continue on with the print job, I'm hoping someone can help me with this issue.
Check your mailing list. Especially check how many invisible spaces are after a name or address. Suspect extra characters are pushing the mailing list into the next page or label and then it will print an extra blank page or label. Seen this happen when I was a Computer System Administrator and had to fix a similar fault for a client.
There is a reveal code option on most word processors that shows up hidden spaces.
May 27, 2015 | Office Equipment & Supplies
How to print barcodes
To print bar codes you first need POS software that will contain all the pertinent information of your products. The software then will generate a bar code and assign it to your individual products allowing them to be scanned for inventory and checkout purpose. You can find labels here: Labeldomain com
May 16, 2014 | Zebra Eltron TLP 2742 Thermal Label...
My printer is printing 3 blank labels before printing the correct label?
Sometimes it's the Internet Browser (if you are printing from an Online Software) and by clicking File ' Page Setup you can make sure margins are set to 0.1 (or as close as possible it may override you) and all six bars below (headers and footers) should be switched to Blank.
Apr 12, 2013 | Zebra S4M Thermal Label Printer
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
Why dose printer eject blank labels after every print
If pressing the FEED key advances just one label at a time then the printer works ok by itself. The printer will only do what it's told to do so so if extra labels feed at the end of printing, then you have to look at the printer driver or the label format for something adding the extra labels.
Hope that helps
Jun 16, 2010 | Zebra 140XiIII Plus Thermal Label Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Smart LabelPrinter Seiko 440
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Seiko Smart Label Printer Pro Thermal
Barcodes not scanning
Very possible you have a bad printhead. If you have a bad dot in your print area, it can cause barcodes to not scan. Look to see if you have a blank vertical line running down your label.
Dec 31, 2008 | Epson TM T90 Printer
Datamax DMX-I-4208 Label Printer Logo
57 people viewed this question
Top Datamax Office Equipment & Supplies Experts
rongg
Johnathon Muise
Level 1 Expert
edy copier
edy copier
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
