Question about Kodak Easyshare C190 12MP Digital Camera with 5x Optical Zoom and 2.7-inch LCD
I have an easyshare c190 and my pics are blurry and the lens doesnt close all the way any sugguestion
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 04, 2010
Kodak easyshare c190 no power after usb
The systems control board is damaged due to a short circuit, this is a job for a camera technician to assess the situation, I recommend a estimate before approval is granted.
Apr 12, 2012 | Kodak Easyshare C190 12MP Digital Camera...
Kodak easyshare c190 digital camera is not reading the memory card
Do you have pics stored on the camera's internal memory? If so, that's the problem. With no card in the camera, go into the menu and find "format" to erase the internal memory. Then insert your card and it should work.
Nov 10, 2011 | Kodak Easyshare C190 12MP Digital Camera...
Kodak C190 camera. I moved my pics from my SD card to my computer. Then tried to transfer them back..after many tries, they are back on my SD card. I can view them by putting the SD card in my laptop. When...
This should do it for you: Insert the SD card into your laptop or computer. In the SD card go to "New Folder" name that folder "DCIM" in the "DCIM" folder create a new folder. This one you will name "101KC190" (I'm pretty sure you have the Kodak Easyshare 190, correct?) Now, transfer all of your pictures into "101KC190." Insert the SD into your camera and it should work. email me if you need to kylejwoody@hotmail.com
Jul 22, 2011 | Kodak Easyshare C190 12MP Digital Camera...
I need instruction manual.All my pictures look clear on camera and blurry on the pc
User Guide:
http://support.en.kodak.com/app/answers/detail/a_id/19182/kw/c190
Extended User Guide:
http://support.en.kodak.com/app/answers/detail/a_id/19155/kw/c190
Nov 28, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Close up pictures
For the jewelry shots you will need an accessory telephoto lens with a macro feature OR a close-up filter set. The lens will give you more features, but the filters will be the less expensive option. The lens should also help with your video shots. I have a Z650, and I use both options - depending on the situation. eBay is a good cost-effective source for these accessories.
Bill B.
San Antonio
May 11, 2009 | Kodak EasyShare Z1275 Digital Camera
When I try to use the timer for a family photo the pic is blurry.
hi check if there is a setting called macro or maybe on your camea there is a symbol that looks like a flower that is for taking close up photos if that is on then your photos will be blurry if this works can you let me know thanks
Dec 20, 2008 | Kodak EasyShare P850 Digital Camera
Blurry parts of pics
Sounds like subject movement. Try using a faster shutter speed
Apr 10, 2017 | Kodak EasyShare Z740 Digital Camera
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
Kodak Easyshare C190 12MP Digital Camera with 5x Optical Zoom and 2.7-inch LCD  Logo
79 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Parshiv Luthra
Are you a Kodak Camera Expert? Answer questions, earn points and help others
