Question about Garmin nuvi 250W GPS Receiver
The device is telling me the battery is low and then shuts down.
  • Garmin Master
  • 589 Answers
If you are using the car cigarette lighter adapter, the fuse could have blown. To check fuse Unscrew the silver tip end of plug CAREFULLY its spring loaded and check fuse....if you used the USB connector to charge unit it must be charged for a few hours to fully charge.
Posted on Nov 04, 2010
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Garmin nuvi GPS Devices,how can i tell when the battery low?
There should be an icon, at the top of the screen, indicating when the battery is low. A portion of the battery means, less than fully charged.
Aug 15, 2014 | Garmin nuvi GPS
Hi, My Acer aspire 5332 keeps shutting down with no warning, I have rebooted approx 7 times each time it will shut itself down.
Have you checked the battery condition indicatot on the lower right hand side of the screen? It may be low and telling the laptop to shut dow.
Hope this helps.
Oct 31, 2010 | Acer Aspire 1202XC (LX.A0105.085) PC...
Dell DJ Ditty fully charged but shutting off due to "low battery"
charge your player and reset and try again if not works
then replace battery of your device that is damaged
Dec 25, 2009 | Dell DJ Ditty MP3 Player
My gps battery says low battery and shuts off when I set it down after putting in travel info. What to do ?
Check the power on your 12v car cord. The internal batteries are low and are not being charged by your vehicle system. The fuse may be burned out in the 12v car plug.
Dec 19, 2009 | Garmin StreetPilot c340 GPS Receiver
When i plug my rca mp3 4208RD-B into the computer port to charge it tells me the battery is full. when i disconnect it and try to turn it on, it says"!low battery shutting down!" how do i successfully...
The battery is probably not the issue. Sounds more like there is an issue internally with the firmware. I suggest reinstalling the firmware, which can be downloaded here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Be sure to back up any important media on your device before performing the reinstall of the firmware.
Oct 23, 2009 | RCA M4208 MP3 Player
After several munutes of on the screen goes to
I have a Garmin Street Pilot c330 which when plugged in and power button pushed, the screen lights up for a few seconds and shuts down. It was giving a low battery warning before shutting down. Where is teh battery in teh unity? and should I replace the fuse?
Apr 22, 2009 | Magellan Maestro 4040 GPS Receiver
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
DELL D520 LAPTOP
Problem cause:
Do diagnose your Laptop try to change your battery or adapter if you have some backup device
Sep 22, 2008 | Dell Computers & Internet
My compaq presario R4000 just stopped working and shut down - no warning - nothing!
bad battery. best way to kill a battery is to always have it charging and never using it or discharging it.
take the battery out and use it just with power cord, see if it shuts down again. or try to use it with JUST the battery if battery is bad the PC will not turn on or stay on
Jan 04, 2008 | HP Compaq Presario R4000 Notebook
Garmin nuvi 250W GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
