SOURCE: Can you please help me, i need a users manual for Washing machine
download from whirlpool.com
SOURCE: whirpool awt 8085/2 it gives
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: Washingmaschine 'whirlpool AWT 9124 not strating
Try this link for description
www.repairclinic.com/Fault-Codes
SOURCE: user manual whirlpool washing machine WFE1070BD
The model number WFE1070BD is not the complete number to look up a manual. This model seems to have been for sale in Australia, so please go to http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/ifu/home with the full code from the sticker on the washer. Enter the commercial code and then the language in which you would like to read the manual and click Search.
If you add a comment with the full code, I may be able to give you the direct link to the manual.
I hope this helps.
