Question about Cameras
My SD card will not go in. It has been fine, took it out this morning to download the images and when I attempted to put it back in, it will not go all the way in
    Guru:
  • 2,178 Answers
The card must have gotten slightly flatten. Try to wiggle it in.
Posted on Nov 04, 2010
  • dick751 Nov 04, 2010
    All I did was take it out, insert in my card reader on the computer like I've done hundreds of times, then tried to put it back in the camera and it only goes in about 90% then stops, like something blocking it. I'm stumped
I have a Nikon D5300. I can see the photo count number increasing, but I cannot view the images and they are not going on the SD card. Where are they? The SD card is not full.
many small Nikon cameras have memory to store images ON THE CAMERA. If you have a memory card installed that the CAMERA CAN READ it will put images on the card. if the memory card is corrupted the camera will not use it.
First Backup all IMAGES on Memory Card to COMPUTER make sure you saved ALL images. This is IMPORTANT.
After you SAVED all images you PUT Memory card back in camera and FORMAT it (Format is in TOOL Menu that looks like a wrench)
Now if you can take an images and it saves to memory card you are done. To see if they go to MEMORY CARD. Turn off camera and remove MEMORY CARD and Check.
If it STILL does not work you may have a defective memory card.
Feb 23, 2017 | Nikon Cameras
Took some photos without memory card. The photos are in the camera's memory, how can I transfer those photos into a memory card?
There are some solutions, but the most easy one is:
1. Take the SD card out of the camera and connect it to the pc to transfer the images. After that, put the SD card back into the camera.
2. There is a menu option in the SP800uz to change the memory to Intern, Extern (SD) and Auto (default). Change it temporary to Intern, connect the camera to the PC and transfer the images. Set the setting back to Auto (or else) afterwards.
Sep 11, 2011 | Olympus SP800UZ Digital Camera
Playsport zx5 won't shut off. Was recording and it just locked up. The screen still shows what the lens sees, but the recording locked up after 4:18. Camera has been on for 3 hours now...
I had this problem. It turned out to the sd card was causing a problem. I took the card out and hit the reset. The turned it back on and it it working great. I ended up copying all the images off the card onto my computer then put the card in the camera and reformatted it. The copied all my images back on to the computer and it is working fine. Hope this helps.
Jun 08, 2011 | Kodak PlaySport Zx5 (0.128 GB) Flash Media...
How to recover erased images from sd card
It is quite possible to recover the photos no matter deleted, formatted, lost or inaccessible from your sd card. All you need to do first is by trying SD card data recovery software tools.
Note: before those files are recovered, never should you attempt to save more data to the card. better stop using it for a moment. Regards.
Jun 18, 2010 | Vivitar DVR-550 DV Camcorder
Can't open SD camera card--error message.
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download a recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
SD Card Photo Recovery
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
You may refer to this tutorial
Recover files from SD Card
hope this helps.
Mar 22, 2009 | SanDisk Sansa e130 MP3 Player
Cannot copy photos from internal memory to SD Card
try to put the back your sd card in your camera then go to option in your camera and search the copy file to memory / copy pictures...i try this in my camera....it works!!!
if this won't work try to download your camera driver/software...
Hope this can solve your problem
Feb 02, 2009 | Cameras
Camera says card write protected
I just figured it out- on my memory card there's a small "switch" on the left hand side that you can slide up and down. Make sure that this is up the top, not down towards where it says Lock. If it's down, this makes the card Write Protected.
Nov 27, 2008 | Canon EOS Rebel XSi Digital Camera
Lexar 1GB SD Card cannot be read.
I had the same problem. i dont know if this will work for yours, but what i did was when i had the card in the slot i pushed in it as far as i could with my finger nail and then it clicked right in.
Aug 08, 2008 | Nikon COOLPIX S200 Digital Camera
I have a canon powershot digital elph. I recently got back from a trip and took my SD card and put it into my laptop and viewed the pictures on my computer. Then I copied and pasted the pictures from my...
Sounds like you are not tackling this the right way.
The proper way is to connect your camera using a USB to mini-D connector direct to the laptop. Use the Import facility to transfer the images to a folder.
Failing that, you don't Copy and Paste, you Right Click Drag.
Insert the SD Card into the laptop slot or a Card Reader to USB. Open File Explorer. Click on the SD card at the bottom of the left hand pane. Highlight the images you want in the right pane, either individually, or multiple (hold down CTRL key, click each one, or hold down SHIFT key, click beginning of block and then end of block of images). Now the clever stuff, Right Click and Drag the images to the folder on the left of the two panes, release the Right Click and choose Copy Here, or Move Here.
I would transfer all the images to your laptop, Format the SD Card in the Camera, and then transfer any images back to the camera if you need, but really, the SD card should be for capturing the images and the computer hard drive for storage, plus backups to Memory Sticks or External Hard Drive.
You can also try using Windows to Repair the Drive (SD Card). Right Click on the SD Card, Properties, Tools, Check for Errors.
Mar 27, 2017 | Cameras
Cameras Logo
24 people viewed this question
Top Cameras Experts
Steve
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
