Question about Sharp AL 1631 Copier
GETTING TWO STRAIGHT LINES ABOUT 2 INCHES IN ON BOTH SIDES FROM BORDER OF PAPER. ONLY HAPPENS WHEN FED FROM TOP OF AL-1631 COPIER. WHATS MY PROBLEM. THANKS BILL 520-294-2594 TUCSON AZ
  • 1,110 Answers
Clean your scanner glass strip. Just lift up the automatic document feeder and look at the large glass. Next to it is a small strip of glass enclosed in a plastic frame. Clean this glass with a soft cloth and some glass cleaner. This will fix your streaks problem as this strip of glass is what is used when you make copies using the feeder. You can verify this by making a copy by laying your original on the large glass. This will probably come out clean with no lines. This will be your proof that the lines are coming from the strip glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 04, 2010
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
May 13, 2011 | Sharp AL 1631 Copier
I get vertical lines running down the middle of paper
lift the lid ull see a thin **** glass make sure its very very clean
Mar 30, 2010 | Sharp AL 1631 Copier
Sharp AL-1631 bottom paper feed will not pick up paper.
A few things could be the problem.
  1. The paper in tray could be damaged
  2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
  3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
  4. Feed tires are worn or dirty
Does the copier try and feed from tray 2? If it tries but the paper doesn't leave the try look and see if there is a dark mark on the page (top middle towards the right). If so then most likely the feed tire is worn.
Oct 12, 2009 | Sharp AL 1631 Copier
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Apr 29, 2009 | Sharp AL 1631 Copier
Thin black line top to bottom 1 inch from left hand side
Check your drum life. Remove the drum and look on the drum surface for a similar line
Jan 05, 2009 | Sharp AL 1631 Copier
LEAVES A BLANK LINE DOWN THE COPY
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Dec 19, 2008 | Sharp AL 1631 Copier
2 parallel lines show up on the copies
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of tha glass specialy the right side.
Apr 11, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 copies very light at top only
Main thing is to absolutely use genuine Sharp toner and drum supplies. After that,probably lamp is not responding are activating quickly enough. Caused by main board or high voltage power supply.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 14, 2007 | Sharp AL 1631 Copier
Feeder misalignment
contact to technician there is need some alighnment of the feeder
Apr 11, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
212 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
